Old 11-29-2012, 11:33 AM   #1
KennyKaozII
Member#: 333257
Default need certain filter!
I am looking for a filter for my 4 inch intake i have built i want a wide filter that can use most of the room of my hood scoop (99 obs) my intake right now is a normal cone and i want more filter covering the scoop? ideas??
KennyKaozII is offline   Reply With Quote
Old 11-29-2012, 01:27 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Do you have a picture of what you're trying to do? It might help out a little bit.
Mike
GrimmSpeed is offline   Reply With Quote
Old 12-02-2012, 02:07 AM   #3
KennyKaozII
Member#: 333257
Here is a link to the pic.... i pounded a sheet metal box out (and threw on some subie gold) to harness the air and bolted it to the stock air box mounts but i need a wider filter instead of this ****ty intimidator cone. Also i want to find a precharge to keep from water its a track project in progress http://i1158.photobucket.com/albums/...pscdceef59.jpg.
Old 12-02-2012, 03:09 AM   #4
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Sooo, you're making a Ganzflow style intake.
Counterfit is offline   Reply With Quote
Old 12-04-2012, 07:08 AM   #5
KennyKaozII
Member#: 333257
Kinda but ive removed the aftermarket box and made a open top one and the cone is inside. I connected the Sensor to the port in the intake. The hood scoop forces air into the box then to the engine i use to have the intake connected to the stock box but i removed it
Old 12-04-2012, 04:56 PM   #6
chuds
Member#: 245141
07 2.5i
cgm
I remember seeing these years ago .
Not sure if you could modify it to work. Obviously you wouldn't need the whole kit.
http://www.speedzonemotorsports.com/...productid=2373
chuds is offline   Reply With Quote
