Old 11-29-2012, 01:16 PM   #1
sunchopper
Member#: 106531
06 WRX
Default Is my power steering pump going bad?
I drive a 2006 WRX TR with approximately 123k miles on it.
About a month ago, my accessory belts began whining, so I replaced the power steering belt and a/c belt with gates belts. The power steering belt was a PAIN to get on... I had to pry it over the alternator pulley with a freaking screwdriver. I tightend the belt down so that the vertical portion of the power steering belt on the right side could be pushed in about a half inch.
A few weeks later, I noticed a whining coming from what I believe was my power steering belt. It seemed to be more noticeable when my car was cold. Shortly after I began noticing the whine, my power steering started to studder from time to time... sometimes at low speeds and more recently even on gradual turns on the highway.
I decided to replace my power steering fluid. Instead of draining it, I got a turkey baster kind of thing and suctioned it all out, refilled it, and drove it around my neighborhood a little bit. I repeated the suctioning/refilling process 3 or 4 times hoping that the fluid was the problem.
The studder did not go away.
I have never opened up the power steering system alllowing air to potentially get in... so based on what I've read, it sounds like my power steering pump may be goin gout. I called a local dealership and they said it was very rare for the pump to go bad. They also said that they thought the pump would run me around $575... ouch. I found this rebuilt pump on RockAuto -> Link that is only $151... so not as bad but also not new.
Is there any possible solution to this problem other than replacing the pump? Is it possible that I just wore the pump out from over tightening the power steering belt? Is there any reason that I might have air in the system even though I haven't done anything to get air in it?
sunchopper is offline   Reply With Quote
Old 11-29-2012, 09:08 PM   #2
awdtoy
Member#: 152728
2006 WRX TR
I had same symptoms with mine a year ago.
Next time you hear that noise take a look at the p/s reservoir and look for signs of air. What condition are the hoses in? Mine were pretty hard and air was getting in past the clamps. Replacing the hoses are a lot cheaper then the pump.
awdtoy is offline   Reply With Quote
Old 11-30-2012, 12:48 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Check the clamp on the suction hose going to the pump and the o ring under the suction plastic fitting. I would replace those first before the pump.
Tony
Old 11-30-2012, 04:31 PM   #4
68Cadillac
Member#: 95901
Visit the rebuild thread for your exact pump. Save Thousands! (of pennies)
68Cadillac is offline   Reply With Quote
Old 12-03-2012, 12:22 PM   #5
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
I'm dealing with a similar issue right now. For the past month or so, I've been getting the whining sound when the car is cold, and then it goes away pretty quickly. I was really hoping it was just a belt issue, so I replaced both accessory belts last night, but no dice. I guess I'll wait a couple days and see if anything changes.
thrasher is offline   Reply With Quote
Old 12-06-2012, 07:04 PM   #6
thrasher
Member#: 40579
2002 WRX Stage 2+
Update from above^^^
After waiting a couple days I re-tightened the new belts. It continues to make the same noise after cold startup whenever the wheel is turned. I have no evidence of leakage, and it almost never shutters during turning. Sometimes at idle speed when I turn the wheel while sitting still it will shake a little, but that's it. Under normal driving conditions I have no symptoms that something is wrong. Also, the stock clamps on my PS lines have already been upgraded to hose clamps, so I really don't think air is the problem.
Does anyone have any other ideas for me to try, or should I get ready to remove/rebuild my PS pump?
Old 12-06-2012, 07:44 PM   #7
Jcoleman134
Member#: 337463
03 Wrx
I am having similar issues also. I dont get any type of wine, but i am getting the studdering after the car gets warm. idk if its a coincidence or not but i just replaced the powersteering belt because it was cracking. ever since i replaced it i have been having the studdering problem.
Jcoleman134 is offline   Reply With Quote
Old 12-06-2012, 09:01 PM   #8
hoffmanEstates
Member#: 122043
04 wagonier
psm
Rebuild it. I fitted a 02-03 pump into my 04 but ya need bracket also or wont work.
hoffmanEstates is offline   Reply With Quote
Old 12-11-2012, 12:50 PM   #9
WRXFanDave
Member#: 151245
2006 WRX Wagon
I had whining and the cold/warm issue you're describing. I was losing fluid slowly. Did the rebuild (posted in the thread referenced above). Car is quiet and happy... Me too.
Rebuild or replace the pump.
WRXFanDave is offline   Reply With Quote
Old 12-11-2012, 02:29 PM   #10
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
OP, don't ignore this!
I had bad juddering symptoms when turning and it turned out to be the 1 o-ring.
The o-ring pack of 50 was like $6 and with screw drivers and 15 minutes I replaced it.... judder GONE.
chimchimm5 is offline   Reply With Quote
Old 12-11-2012, 03:53 PM   #11
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
son of a ***! Ive replaced mine twice with used pumps and the issue keeps coming back in the winter until shes warm... screaming away, I look like i drive a total piece.. gna swith out the clamps and see what gives.. just checked the fluid and looks a bit low but not leaking?
99imprezd is offline   Reply With Quote
Old 12-11-2012, 07:01 PM   #12
WRXFanDave
Member#: 151245
2006 WRX Wagon
Look at the bearing behind the center of the pulley. Bunch of greasy crud? Maybe a slow leak. If you still have your previous used pump, rebuild that sucker.
Old 12-12-2012, 12:19 PM   #13
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
Nah.. this one I salvaged from a 2002 and switched the bracket and its still pretty clean, no crap behind the pulley.. the used ones seem to go on me every 6 months or so..lol. im just gonna replace the clamps on the hoses and see if that helps.. if not, fk it.. Im buyin a new one.
Old 01-01-2014, 05:54 PM   #14
Dezertrat
Member#: 365150
04 Wrx
Aspen white
How long does it take before it's noticeable? My wrx (04) over night developed a steering issue. I can here the pump groan if I'm stopped and I turn the wheel and at low speeds my wheels shutter. It is also significantly harder to turn the wheel. It literally started doing this over night. Possibly pump?
Dezertrat is offline   Reply With Quote
Old 01-01-2014, 07:12 PM   #15
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
Check the fluid level and for leaks..
