Old 01-12-2013, 11:27 PM   #1
KCWRX03
Member#: 343003
2003 Subaru WRX
Default Will a STI TMIC replace my stock 2003 WRX TMIC without any fabrication
Just want to be prepared if I need to buy some supporting parts or will it just easily replace my stock TMIC, thanks
KCWRX03 is offline   Reply With Quote
Old 01-12-2013, 11:47 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
It will swap right in as long as the two hoses are there.
Old 01-13-2013, 12:45 AM   #3
claythrow
Member#: 283663
2004 STI
Root Beer
You need a different y-pipe setup don't you
claythrow is offline   Reply With Quote
Old 01-13-2013, 01:18 AM   #4
SRT6
Member#: 301685
05 Wrx sedan
Yes y pipe and the hose that goes into the throttle body
SRT6 is offline   Reply With Quote
Old 01-13-2013, 06:47 AM   #5
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
You should be able to just drop an sti top mount right in, I have a 2005 rex and a v7 top mount dropped in, nothing had to get swapped from the stock top mount to make the swap work. The Jdm v7 top mount is bigger than a usdm sti top mount and still swapped perfectly. Try to find and sti top mount with its y pipe, don't worry about the throttle body coupler, use your existing coupler.
D-Rodman is offline   Reply With Quote
Old 01-13-2013, 07:07 AM   #6
Tenament
Member#: 246813
imo, go for the ebay intercooler as the price difference between that and the STi one is well worth the absence of the cherry blossom red STi spray decal
Tenament is offline   Reply With Quote
Old 01-13-2013, 11:50 PM   #7
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I painted over that can't even see it.
Old 01-14-2013, 09:36 AM   #8
chrissmith002
Member#: 176046
2002 WRX Sedan
Bull **** I had the ebay one the fitment sucks ass and it won't even bolt all the way on. Not saying it sucks prefomance wise, just go with the sti oem and don't half ass it.
chrissmith002 is offline   Reply With Quote
Old 01-14-2013, 10:07 AM   #9
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
you get what you pay for. There's a reason sti tmic are in demand and cost more than the ebay ones....and its not becuase everyone selling and buying sti tmic's are idiots.
jayman4312 is offline   Reply With Quote
Old 01-14-2013, 10:47 AM   #10
chrisfromalbany
Member#: 67181
I heard that can be a real bitch to install compared to the STi one..
chrisfromalbany is offline   Reply With Quote
Old 01-14-2013, 12:52 PM   #11
Xx02rexxX
Member#: 331883
04 forester xt 5mt
jbp
seems like a decent deal,allthough it doesnt come with a y pipe
http://www.ebay.com/itm/Used-Turbo-X...4f74f8&vxp=mtr
Xx02rexxX is offline   Reply With Quote
Old 01-14-2013, 08:29 PM   #12
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Go ahead, by a cheap aftermarket part that pays no attention to actual air density/cooling properties. Sure, it may flow more, but it's going to also fit like crap and when you upgrade down the road, it will be worth nothing to sell.
Quality OEM parts always fit right the first time, hold their value, and work well for years.
nevin95 LSi is offline   Reply With Quote
Old 01-14-2013, 11:13 PM   #13
wrx43v3r
Member#: 331119
You won't get full use out of it unless you buy an sti hood scoop, sti air splitter and sti rubber gasket. And possibly a new hood because I don't think those parts will fit an 02/03 hood.
wrx43v3r is offline   Reply With Quote
Old 01-14-2013, 11:46 PM   #14
D-Rodman
Member#: 110078
05 saabaru artc gr
Those cheap eBay intercooler are less efficient than an sti unit. You can probably find the results from testing done by a member here, search for it. Its a comparison between a godspeed and sti top mounts. If you just want to open the hood and wow your friends with a huge intercooler then the eBay one is fine. The link you posted is for a turbosx intercooler, that is supposed to be a good unit.
Old 01-14-2013, 11:59 PM   #15
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
Dont bother w Ebay parts imo. If u acquire an STi intercooler. Use STi hard y-pipe or a silicon y- pipe, any silicon coupler for TB fitment and turbo to intercooler-can purchase at siliconhoses.com- u must know ur measures/ sizes needed. Purchase some t- bolts too!! , helps to slot/notch the driver side intercooler support. Long shot but a JDM hood scoop and splitter/seal will nicely finish the job for function and form.
Good luck!
krambte79 is offline   Reply With Quote
