11-29-2012, 09:03 PM | #1 |
Member#: 315212
Vehicle:2003 WRX Sedan Aspen White |
DIY WRX Skid plate
Did another little project! Didn't want to fork out a lot of money for a skid plate since my original splash guard was missing so I grabbed some old aluminum signs from work and started making it.
It was make using aluminum signs, 3/16 rivets to hold it all together and a couple steel tabs. Here is the basic shape with some dimensions: Back side: Bent some side flairs up to fit flush around the frame: Cut two holes in it for the oil filter and drain plug: But....didn't want to leave the holes open so stuff could get up on top of it so I fashioned a cover: Here are the steel tabs the one end slides into: The other end is held in place by one of the rear plate bolts, so when you want to access the filter and drain plug all you have to do is undo one bolt and slide off the cover. Here it is all finished: Back side with some high heat silver paint: Everything bolts up to the factory threads for the original splashguard. All are 5/16 bolts. The nuts are for spacers between the plate and the frame in the front. There is two rubber spacers for the rear spot with the two longer 5/16 bolts: I will get a picture of it on the car tomorrow. I am having it worked on tomorrow and I figured I'd leave it off for them :P
11-29-2012, 09:36 PM | #2 |
Medium Frank
Moderator Member#: 140114
Vehicle:2020 Subaru Outback |
Nice!
11-29-2012, 09:40 PM | #3 |
Member#: 332561
Vehicle:2015 GTI Autobahn White |
Very cool work
11-29-2012, 10:40 PM | #4 |
Member#: 251434
NWIC
Vehicle:15 wrx shadow black |
Subscribed for future use. Just need to commit a federal offense.
11-29-2012, 10:52 PM | #5 |
Member#: 322385
Beggin' to be made from a "SLOW CHILDREN" sign.
11-30-2012, 08:08 AM | #6 |
Member#: 292532
NESIC
Vehicle:05 STI PSM |
This is awesome
11-30-2012, 11:28 AM | #7 |
Member#: 290974
Vehicle:2005 WRX Wagon PSM |
11-30-2012, 06:10 PM | #8 |
Member#: 298417
South East
Vehicle:2005 STI WRB |
Thats awesome! as long as they're not city or state signs it's not a crime!
11-30-2012, 06:12 PM | #9 |
Member#: 97043
TXIC
Vehicle:08 STI 02 Z28 - project |
MacGyver Approved!
Do yourself a favor and fashion a true locking mechanism for that removable shield. Best/easiest to use a rivet as a pivot point so your cover doesn't EVER fall out and slice something nasty.... like fuel lines, tires, or someone else. |
11-30-2012, 07:17 PM | #10 | |
Member#: 315212
Thanks for the advice! |
11-30-2012, 07:58 PM | #11 |
Member#: 97043
TXIC
Missed the rear bolt locking it down. Lock washer, nylon nut, or lock tite and done. Good stuff.
Flea markets are another source for signs guys. Don't go vandalizing unless you know that option |
12-01-2012, 12:40 AM | #12 |
Member#: 315212
12-01-2012, 03:01 PM | #13 |
Member#: 89628
Vehicle:'02 Wagon VF39'd & Quick Racked |
Ghettoriffic! I love it. I may try this with a "Slow Children" and a Crosswalk sign. And leave them paint side out.
12-01-2012, 03:36 PM | #14 |
Member#: 290974
Assuming you change your own oil but...... This would require you to take your car somewhere to have the oil changed just to get a reaction out of a mechanic
12-01-2012, 04:03 PM | #15 |
Member#: 89628
Awesome.... "I wondered what was banging around down there for the last month?"
12-01-2012, 04:17 PM | #16 |
Member#: 97043
TXIC
Good reason to bring car ramps to a meet. Weird out the non Subie guys haha
12-01-2012, 07:14 PM | #17 |
Member#: 315212
Pics On Car
For those who wanted to see what it looks like on the car here go!
Heres how big the access hole for the filter is: Access holes: And on the car: .......this morning I will be looking for parts soon |
12-01-2012, 07:54 PM | #18 |
Member#: 294069
Vehicle:98 Forester Green |
sad day for your subaru
on a happy note.. i was also wanting to do this.. any idea where to get signs? or how to bend up the front? other than that i would just drill holes and bolt them together.. and make a much bigger access hole.. usually i spill everywhere/cant get the filter out. |
12-01-2012, 08:10 PM | #19 | |
Member#: 315212
I got mine from work, they were old signs that we changed out and they were going to be thrown out so I snagged them. Your best bet is to check a scrap metal shop for old signs. For the edge I use a vice to bend it M |
12-01-2012, 08:29 PM | #20 |
Member#: 294069
thanks man.. good luck fixing your subaru
12-01-2012, 08:33 PM | #21 |
Member#: 315212
12-01-2012, 08:40 PM | #22 |
Member#: 321498
International
Vehicle:2006 Outback Black |
Very crafty! Bookmarking this for the future...
01-15-2014, 07:46 AM | #23 |
Member#: 153412
Vehicle:1998 Impreza wrxRS Black |
Sub'd
01-15-2014, 11:27 AM | #24 |
Member#: 378810
Crafty! I like it!
01-15-2014, 01:23 PM | #25 |
Member#: 275131
NESIC
Vehicle:2005 WRX (AW) 2007 CBR1000rr Boosted!! |
