Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Old 09-12-2002, 03:50 PM   #1
cds
Member#: 24489
Default why so much front overhang?
I'm thinking about getting a WRX but I don't understand why the engine is entirely in front of the front axle. I thought these cars were designed as AWD "from the ground up" but the front-heavy, front-overhang format seems like a FWD compromise. Why not an even front/rear weight distribution with the front wheel further forward? Thanks.
cds is offline   Reply With Quote
Old 09-12-2002, 04:41 PM   #2
JGard
pooptastic
Member#: 1904
2011 BMW X5 35D
01 Miata red
because the front differential is in the transmission, which is behind the engine. That's why the engine is in front of the axle.
Most FWD cars, the engine is ON the axle, since they use a sideways engine and transaxle.
As for weight, yes, the car is set up to understeer, almost all cars are, it's a safety thing. Don't think for a second, though, that you can't get snap-oversteer on this car, because many people have done it (usually by mistake).
Plus, most of the weight is in the AWD system itself, which is low and centered.
JGard is offline   Reply With Quote
Old 09-12-2002, 04:53 PM   #3
cds
Member#: 24489
Default but why not put the front axle nearer to the front?
Thanks for the reply but I still don't understand why the front axle isn't further forward, like on a BMW 3 Series. Can't they leave everything else the same and just put the front wheels all the way up front for better balance? It looks like the car is likely sold as a FWD car in countries where fuel is much more expensive and AWD is, therefore, undesireable.
Thanks again.
Old 09-12-2002, 05:01 PM   #4
JGard
pooptastic
Member#: 1904
2011 BMW X5 35D
01 Miata red
if Subaru tried to move their front wheels all the way up like that, then they would have to redesign their whole AWD system.
The way it works now is that the transmission comes off the back of the engine. Right off the front of the transmission (near the engine), the front CV shafts come out and go to the wheels. Then out the back, the driveshaft goes to the rear differential.
So you see, they'd have to put a whole different transmission/front diff. assembly in the car in order to do what you want to do.
What they have now works very very well, why would they change it?
Old 09-12-2002, 05:09 PM   #5
cds
Member#: 24489
Default I see . . .
Got it -- the power would have to be redirected further forward somehow, instead of being used right where it comes out. Thanks.
I suppose the only reason to change it would be to get the more neutral handling of 50/50 weight distribution, instead of having almost 60% of the car's weight on the front tires. Now I see that it would not be a simple improvement to make. Thanks again.
Why so much $$ for Body kits? fiberglass doesnt cost that much! D.Sweet86 Interior & Exterior Modification 5 06-07-2005 09:45 PM
Carbotech Bobcats and why so much rotor wear? ricky03 Brakes, Steering & Suspension 5 03-24-2004 02:21 PM
Why so much backfiring?? kschmohl Mid Atlantic Impreza Club -- MAIC 19 07-27-2003 01:05 AM
Why so much hate for SUV's??? I am b Off-Topic 90 01-08-2003 11:08 PM
Why so much price difference in rims??? Drew888 Interior & Exterior Modification 29 07-21-2001 12:44 PM
