Welcome to the North American Subaru Impreza Owners Club Friday December 26, 2014
Old 11-25-2012, 09:17 PM   #1
shame_16
Member#: 227690
Default STI swap into Baja. Help!
I have a 06 Baja and installed STI TMIC, VF43 and 04 STI Ecu. Engine barely idles and runs rough. The A/F (oxygen sensor) readings are at 3.8v and higher. Im reading -120ma at the ecu. Also the short term fuel trims are maxed out at +25 which im pretty sure means its running very lean. I do not have access to the ECU pinout on my Baja ecu. With the Baja ecu in it idles fine and I can at least drive it. The oxygen sensor reading with the Baja ecu are within the normal ranges. I currently have my Baja ecu installed so i can limp the car around. Is there a difference betweens the pinouts or is there a difference in O2
sensors? Thanks
shame_16 is offline   Reply With Quote
Old 11-25-2012, 10:53 PM   #2
lgt2000
Member#: 140073
2005 LGT
Red
It sounds like you had a turbo baja with a VF40 and upgraded to the VF43. If that is the case I would keep the Baja ECU, get a wideband and tune for the new turbo
lgt2000 is offline   Reply With Quote
Old 11-25-2012, 11:09 PM   #3
shame_16
Member#: 227690
I'm not opposed to that. Closest reputable tuner is in Atl. I'm in the Florida panhandle. I would like to have this Sti ecu work with it though. At least until I can make a road trip.
Old 11-26-2012, 02:16 PM   #4
lgt2000
Member#: 140073
2005 LGT
Red
I would pick up a tactrix cable and do an email tune to get on the road. I have not compared the ECU pinouts but it may be more work to try and use the STI ECU
Old 11-26-2012, 08:31 PM   #5
shame_16
Member#: 227690
How would I go about getting an email tune?
