Old 11-30-2012, 09:13 PM   #1
M///Scooby
Member#: 28117
2012 WRX
Default Spring compressor needed?
Im going to be installing some coilovers and I was wondering if the front and rears require a spring compressor before removal.
It looks like the fronts will, but not sure about the rears.
Any help will be great.
EDIT: for a 2012 WRX hatch.
M///Scooby is offline   Reply With Quote
Old 11-30-2012, 10:05 PM   #2
teiva-boy
Member#: 22825
The fronts would if you are taking off the tophats, but removing the whole strut as one piece, you wouldn't. It's a mcpherson strut right?
The rears, I'm not familiar with, if it's a full strut or a spring and separate shock. But I doubt you need any.
teiva-boy is offline   Reply With Quote
Old 11-30-2012, 11:22 PM   #3
M///Scooby
Member#: 28117
2012 WRX
I will be taking them off and one piece.
Old 12-01-2012, 03:42 AM   #4
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
easy way to check is once the strut is off the car see if you can compress the spring by hand enough that it breaks contact with the strut top, if yes then they are not going to be compressed enough to worry about using spring compressors.
JDwhiteWRX is offline   Reply With Quote
Old 12-01-2012, 10:03 AM   #5
02nismokiller
Member#: 322963
04 wrx
psm
It's really dangerous if you've never done it before using a spring compressor.... Don't try and take the top hats off without first compressing the spring unless you want to look like a pirate losing an eye or a tooth
02nismokiller is offline   Reply With Quote
Old 12-01-2012, 12:20 PM   #6
04Silverex
Member#: 77322
2016 STi
Cwp
No you don't need spring compressors to take the struts off the car, the rears you will need to unbolt the lower control arm to remove the shock/spring setup
04Silverex is offline   Reply With Quote
Old 12-01-2012, 07:09 PM   #7
sc00by4life
Member#: 97135
Just an FYI, making multiple threads can get your account banned.
Old 12-02-2012, 08:50 PM   #8
chino_487
Member#: 209156
2009 WRX Sedan
SSM
i could have sworn i saw this before. i had to make sure i wasnt smoking something.
chino_487 is offline   Reply With Quote
Old 12-03-2012, 04:57 PM   #9
opfed
Member#: 296033
2011 WRX
WR Blue
I installed the Eibach pro kit on my 2011 sedan and needed a spring compressor. I was unable to tread the top nut without it. Added a good 15 minutes to each corner. If you have a helper maybe he can press down on the top hat while you tread the nut.
opfed is offline   Reply With Quote
