Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 12-01-2012, 08:25 AM   #1
Amaze
Member#: 328550
2009 Impreza WRX STi
Dark Grey Metallic
Default Randomly started running lean today?
I have an 09 STi, stock except for COBB SF Intake + Airbox and Cobb AP. I was running the stage 1 sf intake + airbox 93 octane tune, and everything had been running fine until now. In 1st through 4th gear my afr fluctuates constantly between 13.5 and 12.9, somewhere around there. In 5th, and ESPECIALLY 6th gear, just cruising on the highway around 2700 RPMs making no boost, my AFR is in the 12's, sometimes as low as 12.2. Then randomly out of nowhere it will go back up to about 13.1 and drop back down to 12's only a few seconds later. WOT is usually in the low 11's. I have prosport gauges though, so could they possibly just be giving me a crappy reading?
Amaze is offline   Reply With Quote
Old 12-01-2012, 08:30 AM   #2
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
Running in the 12's while cruising is RICH. Way too rich for cruising. 13.1 is still way too rich for cruising. Low 11's in WOT isn't really too lean. Are you sure your wideband is accurate? I've only used romraider so I'm not sure if the accessport can do it but does it allow you to log the car's O2 sensor? If it does, the car's O2 sensor will be more accurate then your wideband (while cruising).
codesoccer is offline   Reply With Quote
Old 12-01-2012, 09:44 AM   #3
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
Sounds like you're using a wideband sensor with prosport to read your afr? If you're getting 13 in cruising situations, the most likely explanation is that your gauge is inaccurate. Prosports aren't exactly know for their stellar reliability.
Ziggyrama is offline   Reply With Quote
Old 12-01-2012, 11:25 AM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Have you gotten a CEL indicating too lean or rich?
Old 12-01-2012, 11:26 AM   #5
art@grimmspeed
Member#: 301037
2004 Forester XT
I would bet the gauges are off. Until you find out for sure I would not be in boost too much.
art@grimmspeed is offline   Reply With Quote
Old 12-01-2012, 04:12 PM   #6
Davenow
Member#: 23676
First off you are running RICH, not lean. You should be at or around 14.7 while cruising. Lower numbers=richer.
Second, prosport gauges are rebadged ebay glowshifts. This isn't a guess, I have had both apart in my hands at the same time, they are IDENTICAL, so yes, your gauges are almost definitely giving you bad info. Even if by some miracle its right, its still a junk gauge.
Your motor costs a lot more than a decent set of gauges. Buy quality gauges.
Old 12-01-2012, 04:25 PM   #7
Amaze
Member#: 328550
Dark Grey Metallic
I haven't in over a month since i installed the Cobb AP
Old 12-01-2012, 05:46 PM   #8
Amaze
Member#: 328550
Dark Grey Metallic
I'm really just confused right now lol first my car is running too lean so I buy the AP and now it's too rich. I tried reflashing and nothing happened. If I uninstalled and reinstalled my map would that help?
Old 12-01-2012, 06:03 PM   #9
sc00by4life
Member#: 97135
What made you think it was lean before the AP or are you drinking the kool aid?
Old 12-01-2012, 06:06 PM   #10
Amaze
Member#: 328550
Dark Grey Metallic
Here's a data log I took just driving around my neighborhood real quick if you guys can figure anything out from this
http://www.4shared.com/file/1y_HBGfz/datalog1.html
Old 12-04-2012, 10:47 PM   #11
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
You posted it using a site that wants us to sign up for the service.
Just post a screen shot. Help us help you!
sackytar is online now   Reply With Quote
Old 12-05-2012, 07:25 AM   #12
SpamBot
Member#: 287534
Please define "stock" again for me?
SpamBot is offline   Reply With Quote
Old 12-05-2012, 07:34 AM   #13
meat_WRX
Member#: 96919
2004 sti
black
We're you going off the Prosport for you afr's in stock and modded form? Buy a AEM wide band please then get back to us. Or get on a dyno and do some pulls while logging your afr's with the dyno's sensor
meat_WRX is offline   Reply With Quote
Old 12-05-2012, 09:11 AM   #14
HonduhPowa
Member#: 269076
2012 Wrx
Innovate Mtx-l Wideband ftw.
HonduhPowa is offline   Reply With Quote
