Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 12-01-2012, 08:17 PM   #1
mrtimroxass
Member#: 206813
2007 sti
ugm
Default cant fill up my car fully
the past fillups ive been only able to get 12 gallons at most at the tank. i know my car which is a 2007 subaru sit can get 14-15 gallons. can someone help me out please on how to fix this issue. thank you in advance.
mrtimroxass is offline   Reply With Quote
Old 12-01-2012, 08:21 PM   #2
milocas
Member#: 201641
2010 Legacy Gt Prem.
D4S
The extra 2 to 3 gallons is added with our reservoir tank! our primary tank holds 12 gallons.
milocas is offline   Reply With Quote
Old 12-01-2012, 08:33 PM   #3
J-hop
Member#: 318428
On a side note don't try to top it off. I see a lot of people who once it clicks they try to pump more in, do not do this, once it clicks stop... (Not to mention its pretty silly because you probably only add another 5 or so miles worth of fuel), you can muck up the EVAP system pretty good.
J-hop is offline   Reply With Quote
Old 12-02-2012, 02:58 AM   #4
mrtimroxass
Member#: 206813
2007 sti
ugm
But usually filling uup with my gas light on i get 14 And lately when i fill up my gas gauge does not read full.
Old 12-02-2012, 10:43 AM   #5
J-hop
Member#: 318428
Well are you one of those people that keeps trying to pump after the first click? If you do that enough your EVAP may eventually not be able to vent properly and you will have trouble filling the tank up...
As a side note it is hard on the pumps to be running them down right to the bottom all the time.
Old 12-02-2012, 11:07 AM   #6
sc00by4life
Member#: 97135
herp derp.
Old 12-02-2012, 12:11 PM   #7
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
I'm pretty sure Subaru didn't put a reserve tank in their cars.
i_c_the_light is offline   Reply With Quote
Old 12-02-2012, 12:17 PM   #8
WRXSteye20008
Member#: 175565
2014 Sport Premium
Past: 351awhp Sti
Same info, said twice in a different way
OP are you losing gas milage no? Don't worry about it, I think you are thinking to much into it. IF the needle stops and stays at a certain level and never reaches the full line, then it is the float is stuck etc, etc.
WRXSteye20008 is offline   Reply With Quote
Old 12-02-2012, 12:31 PM   #9
J-hop
Member#: 318428
^ not exactly, 1st time I stated overfilling can damage your EVAP system second post I asked if he had been overfilling it and explained why damaging the EVAP system matters to this case.
just trying to pull more info from the OP because 90% of the time I've found when a car consistently refuses to let the tank fill it is an evap issue and with a car that new it would have to be something out of the ordinary like misuse (topping up).
The float issue is also a possibility but again it seems so odd with a car that new.
Old 12-02-2012, 04:00 PM   #10
S1CkWrx
Member#: 325249
2012 wrx
dgm
im actually having a somewhat simular issue, i never topp off the car after it pops it 99% of the time fills right up to full! but recently i got gas and the gauge didnt fully read full... '12 wrx.it was about a line from the full line.
S1CkWrx is offline   Reply With Quote
Old 12-02-2012, 10:51 PM   #11
JordanM9
Member#: 273214
2013 WRX Limited
CBP
hmm every time the pump shuts off on me my gauge will go just a little bit past the "Full" line
JordanM9 is offline   Reply With Quote
