Notices
Old 12-01-2012, 08:21 PM   #1
filipin0y
Member#: 216968
2oo2 wrx sedan
psm!
Default newb question on camber kits for 02 wrx
my rear camber and toe are all out of wack due to an accident i had gotten into a while back. what are my options in rear camber kits and if any that also adjust toe past factory settings. i dont wanna run camber bolts cuz they seem a little too cheap.
what brands and makers make adjustable rear camber for 02 wrxs?
filipin0y is offline   Reply With Quote
Old 12-01-2012, 09:58 PM   #2
sc00by4life
Member#: 97135
I would imagine things are bent or broken if alignment is out of spec with OEM parts. There is no rear camber adjustment, so your only options with stock suspension are $30 bolts, or 400+ on whiteline/msi top hats. You can also get adjustable rear lateral links.
In terms of toe adjustment....not sure why youd want rear toe adjustment on a street car, on our cars you want 0 toe all around.
Old 12-01-2012, 11:37 PM   #3
leecea
Member#: 37359
2003 WRX
Adjustable lateral links will let you adjust camber and toe. I don't know if the Whiteline pieces are any good, but here is a link: http://www.jscspeed.com/catalog/Whit...TI-1821-1.html
Good idea to figure out what is bent too, as it may need to be fixed rather than just masking the issue.
leecea is offline   Reply With Quote
Old 12-01-2012, 11:50 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
For the love of all that is holy man...you need to fix what is broken, not perform a ghetto fabulous fix. If you are smart enough to know the reasons to adjust toe and camber for performance, then you are smart enough to know what you are doing is a knuckleheaded idea.
Old 12-02-2012, 12:15 AM   #5
scoobynoobEMT
Member#: 199206
2002 WRX wagon EJ257
All I could think of was that being read in Ron Burgundy's voice.
scoobynoobEMT is offline   Reply With Quote
Old 12-02-2012, 07:59 PM   #6
filipin0y
Member#: 216968
2oo2 wrx sedan
psm!
the whips salvage title. nothings broken the whole subframe isnt aligned. one side has more camber. trust me ive looked at everything in and out. chill out breh im just asking if theres any camber kits for the rear to fix it out, not a ****en lecture from mom and pops
Old 12-02-2012, 08:00 PM   #7
filipin0y
Member#: 216968
2oo2 wrx sedan
psm!
do those lateral links work any good? look a lot better than getting tophats
Old 12-02-2012, 08:26 PM   #8
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
A good alighnment shop could fix that for you. If you were close I could fix it for you.
Pop
Old 12-02-2012, 08:54 PM   #9
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Chill out. He's giving you good advice. Get it realligned. Leave the ghetto fixes for the ricers.
Navendra94 is offline   Reply With Quote
Old 12-02-2012, 10:53 PM   #10
sc00by4life
Member#: 97135
what you don't seem to understand, is that there is NO STOCK CAMBER ADJUSTMENT in the rear.
if your alignment is out of spec, SOMETHING is bent or broken. You might not be able to see it, or don't quite know what it might look like, but something is bent or broken. there is no question about that.
Old 12-02-2012, 11:00 PM   #11
leecea
Member#: 37359
2003 WRX
The impression I got was the he knows the frame/sub-frame is bent and just wants a band aid solution to compensate for that. Sounds dicey but I guess there's a reason camber bolts are also called crash bolts.
Old 12-02-2012, 11:32 PM   #12
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Is it strange that as I scrolled down I read that in Ron Burgundy's voice as well? Even without seeing who made the response or your response?
drewvdw is offline   Reply With Quote
