#1 |
Member#: 268190
TXIC
hey everyone i start to do a trial n error wide body. I'm just experimenting on how wide and what style wide body i want.
should i use my templates to make the widebody in sheet metal? or would it be better to make a fiberglass mold and make an overfender? here are pics: ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Member#: 268190
TXIC
so ive decided on fiberglass. it is alot cheaper and easier to shape.
anyone have advice on what fiberglass, resin, gel coat, i should use? i also read on something named tiger hair. |
#3 |
Member#: 272090
Tiger hair won't work for you. Its a heavy bodied filler mixed with glass. You need your initial coat down first. Make a plaster or clay mold fiberglass over it. You need all your contours and what not first. If you don't have a lot of body experience I would have someone help you or don't bother attempting the task yourself.
#4 |
Member#: 268190
TXIC
Yeah I'm gonna use styrofoam, and polyurethane expanding foam to cut and shape the width and contour.
Then lay plasticine, resin w/hardener, fiberglass woven cloth, to make the mold. My goal is to make a rivet on overfender with a flare around 90mm. Right now I'm just researching. When I get the funds then I'll actually attempt it. If anyone has advice on what the best quality and reasonably priced products to use. I'm all ears. |
#5 |
Member#: 16149
Vehicle:2001 impreza 2.5RS blue |
Check out this forum: http://www.fiberglassforums.com/
There are a lot of build threads, advice on what products they prefer, etc. But you are only given a certain amount of threads you can read, then, ask you to register (free). |
#6 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, 1,000,000 whp 2 aw tq |
mod some kakumi flairs? I dont know anyone that would need more tire than what a karlton flare will hold though. You could alway tub it and go with a 9" rear.
#7 |
Member#: 284046
NESIC
Vehicle:2000 Impreza w/ WRX |
The work involved to do this would be staggering.
#8 |
Member#: 122043
Vehicle:04 wagonier psm |
Bleh..........
