Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 12-02-2012, 12:43 PM   #1
Francois_
Member#: 284101
2004 STI
world rally blue
Default More cooling problems
So last night when I got home, I parked, car was fine, temps were fine. I shut the car off and about 30 seconds later I turned the key to the on position to roll up the window and noticed the temps were at the 3rd line and the fans kicked on. Once again, it was fine when I was driving home.
So this morning, I come outside to take a look at it. Popped the coolant res by the turbo and noticed it was a little low. So I topped it off and bled it a little bit. I start the car, it warms up fine, gets to operating temp and stays there. After about 5 minutes of it being at operating temp and not overheating, I shut it down. Then I put the key to the on position again and sure enough the temps started to rise and the fans kicked on.
The temperatures only start to increase once the car is shut off. Which makes sense seeing as how coolant flow has stopped and the engine is hot. But enough to raise the needle and turn the fans on?
Not really sure what is going on. The heat works, radiator hoses are warm, and nothing is leaking. Any ideas as to what to look at next?
Thanks for any input
Francois_ is offline   Reply With Quote
Old 12-03-2012, 03:42 AM   #2
Tdaz250
Member#: 310744
02 WRX
How many miles?
Tdaz250 is offline   Reply With Quote
Old 12-03-2012, 10:32 AM   #3
Francois_
Member#: 284101
2004 STI
world rally blue
Built motor has a little less than 30k miles
Old 12-03-2012, 11:16 AM   #4
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
Have you tried burping the upper turbo coolant reservoir? I was having a similar issue on my ej207 and that's all it was. Basically take off the top cap, start the car, watch for bubbles coming up through the coolant, grip the upper coolant hose and give it a few squeezes, watch for more bubbles. The upper rez should start to fill a bit, when it's fully pressurized add some coolant and top it off. Turn off the engine, replace the cap and you should be good. I had some air in my system due to a tiny coolant leak on my lower rad hose on the drivers side. Hope this helps.
Mr.Chow is offline   Reply With Quote
Old 12-03-2012, 12:15 PM   #5
Francois_
Member#: 284101
2004 STI
world rally blue
I did that yesterday. And all seemed fine til I shut it off.
Could it be coolant temp sensor related? Maybe the fans aren't coming on when they're supposed to?
Old 12-03-2012, 12:45 PM   #6
Francois_
Member#: 284101
2004 STI
world rally blue
Never mind, don't think it's that. I just took the car for a test drive around the block to see how it was acting since I haven't driven it since the problem happened two days ago.
I let it warm up most of the way. When I started to drive, it continued to warm up to just about full operating temp. I got back home and parked and shut it off. When I turned the key back on, the fans came on immediately and the temp rose a tiny bit.
So I drove it barely enough to get it to operating temp and it still got hot enough to turn the fans on when I turned it off. Seems really weird.
Old 12-03-2012, 01:36 PM   #7
rick-l
Member#: 33868
2003 wrx
srp
I don't understand what the problem is.
rick-l is offline   Reply With Quote
Old 12-03-2012, 01:39 PM   #8
Francois_
Member#: 284101
2004 STI
world rally blue
It's overheating upon shut off.
Old 12-03-2012, 02:27 PM   #9
michael everson
Member#: 336368
blue
Its not overheating. Its acting normally. All cars do this. Coolant stops flowing and then starts to heat up. No big deal.
Mike
michael everson is offline   Reply With Quote
Old 12-03-2012, 02:35 PM   #10
Francois_
Member#: 284101
2004 STI
world rally blue
Mike
I've just never had the fans come on that early. I understand how it will heat up on shut off but it's never been this prominent.
