Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 12-02-2012, 02:04 PM   #1
Member#: 314134
02 wrx
midnight black
Default 02 wrx turbo spool noise screech after boost
About two weeks ago on my way to work I was shifting into 5th at around 4500-5000 rpm. Coming out of boost I hear a screech from the turbo. Its not very loud. I was told the turbo is an sti turbo the previous owner had the turbo replaced about 3 months before I bought the car. The car also came with a 3 inch down pipe, full exhaust and intake. I have since then I upgraded to a silicone turbo inlet and hard inter cooler piping. I can see the turbo is newer but still looks small to me. Yesterday on my way to work the car not yet wormed up shifting into 5th at 5000 rpm I here the noise again. I have only herd the noise twice. The car 02 wrx
jarrodblake is offline   Reply With Quote
Old 12-02-2012, 02:07 PM   #2
Member#: 316415
2006 WRX
Stop driving your car until its at operating temps first of alll.
Andrewxxcarlson is offline   Reply With Quote
Old 12-02-2012, 03:04 PM   #3
Member#: 301136
You seriously rev to 5K RPM before your car is warmed up? Good luck with that...
djdalaney is offline   Reply With Quote
Old 12-02-2012, 03:07 PM   #4
Member#: 226864
Stay under 3k rpm until the car is warmed up.
Also, did you check for shaft play on that turbo before you installed it? You got everything tuned right?
lavid2002 is offline   Reply With Quote
Old 12-03-2012, 09:52 PM   #5
Member#: 316107
2002 Wrx sportwagon
Rally blue
My vote is stock td04 and you sucked cat from your uppipe into it
boosted25 is offline   Reply With Quote
Old 12-04-2012, 05:25 PM   #6
Member#: 149262
03WR Rallycar/FXT/OB
Recheck your connections.
sackytar is offline   Reply With Quote
