Old 12-02-2012, 04:06 PM   #1
andysoto24
Member#: 339025
2007 RS
Urban Grey Metallica
Default Headlight Issues
Hey I'm a sooby noob and one of my headlights just burnt out. I went out to autozone and purchased an H7 bulb
To be exact
Now when I went to change it I noticed that the bulb that's out and the bulb I purchased look like two different things.
andysoto24 is offline   Reply With Quote
Old 12-02-2012, 04:16 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You only needed to post this once, I deleted your other post in the sticky thread.
If your low beam bulb is out, which is what you are indicating in the pic, it is in fact an H7 and you bought the correct bulb (although the Silverstars are a waste of money and you should have just bought the generic H7's from the store). If you think the bulbs are different you're looking at the wrong one.
Old 12-02-2012, 04:18 PM   #3
andysoto24
Member#: 339025
2007 RS
Ok thanks a lot!
I posted on the sticky my mistake and tried to delete the post thanks for that
Old 12-02-2012, 04:40 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yeah you can't delete posts, in the future use the "Report Post" button and a moderator will do it for you.
Old 12-02-2012, 09:10 PM   #5
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
The H7 is indeed the correct bulb, IF someone didn't make some changes prior to you buying the car. If you got the car pre-owned then the previous owner might have installed a plug n play HID kit (or done a complete retrofit) meaning the bulb you removed was an HID bulb.
Can you take a picture of the 2 bulbs (don't open the new bulb yet so you can return it and get a better halogen bulb)
A picture of the housing would be helpful too since a plug n play HID setup doesn't change where the bulb inserts vs a retro fit which has a different socket for the bulb to go into.
aerosaaber is offline   Reply With Quote
Old 12-03-2012, 11:20 AM   #6
andysoto24
Member#: 339025
2007 RS
Hey thanks for all the help. I'll get right on that picture.
Can I ask what's the differences between the bulb I purchased and the halogen bulb?
