Old 12-03-2012, 05:03 PM   #101
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
nice read so far
OP make sure you update with your/shop's final synopsis
AliBenn is offline   Reply With Quote
Old 12-03-2012, 05:15 PM   #102
lvlatthew
Member#: 336712
2002 bugeye wrx
Originally Posted by AliBenn
nice read so far
Well the synopsis ATM is he changed my oil to the correct amount. I have good oil pressure and everything. He said you should have nothing to worry about.
And he quoted me on a timing belt replacement for around 1000$ and I may gett it after this winter
lvlatthew is offline   Reply With Quote
Old 12-03-2012, 05:30 PM   #103
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Did he say how they checked the pressure? Or did he just start it an no light came on?
KillerBMotorsport is offline   Reply With Quote
Old 12-03-2012, 05:57 PM   #104
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Originally Posted by vision.dynamix View Post
Royal Purple and Mobil1 5W30 are teh 2 worst oils you can put in a turbocharged Subaru.
Stop using Mobile 1 and RP. Check your oil early and often as these cars eat it.
$1000 for a timing belt is robbery. Not even close. You can buy the entire Gates replacement kit with the tensioner and pulleys and belt for about $300 or so. Labor should run you another $300 or so. A local Subaru shop can knock it out in an afternoon easy.
Or buy a case of beer and pizza and invite over some locals and learn how to do it yourself.
Old 12-03-2012, 06:08 PM   #105
lvlatthew
Member#: 336712
2002 bugeye wrx
Did not state how he checked. But I could also check myself by buying one of those things mentioned earlier in this post? He said it was good so I took his word.
And the timing belt was a rough estimate. I don't plan on bringing it to the same guy. I would rather bring it to a Subaru place to do it.
Old 12-03-2012, 06:30 PM   #106
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
He changed the oil, started it, and called it good. Your "friend" isn't doing any sort of favors for you.
At this point it truly is beating a dead horse. We told you what to do to PROPERLY figure this out, you argued it with us and your father, and ended up just getting an oil change. If the motor lasts, then great it was a fluke. If the motor goes, told you so.
Timing belt change is 105K miles or 105 months. Which ever comes first. Never ASSUME something is good with a car or you can put it off, otherwise a 10 dollar fix will turn into 1,000 or more.
Any more questions? I honestly feel like it's not getting to you.
Old 12-03-2012, 06:35 PM   #107
lvlatthew
Member#: 336712
2002 bugeye wrx
I can't control what he does man.
Old 12-03-2012, 06:50 PM   #108
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Who asked you to control what someone else does?
Old 12-03-2012, 06:52 PM   #109
lvlatthew
Member#: 336712
2002 bugeye wrx
I asked the guy to check out the damn pickup he says it isn't needed because we have good oil pressure an he didn't wanna get into a big job for nothing.
Old 12-03-2012, 07:01 PM   #110
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
You asked him to check the oil pick up, which is INSIDE the oil pan. He changed your oil. Do you not see how this isn't the same?
We're not asking you to control someone else. But, as a consumer and your mechanic providing a service, you can tell him what to do. An oil change is not checking the oil pick up.
Old 12-03-2012, 07:06 PM   #111
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Are you paying him?
Old 12-03-2012, 07:08 PM   #112
lvlatthew
Member#: 336712
2002 bugeye wrx
I understand he wasn't concerned that this wasnt *the problem. As Honda something said before. It seems like people are making it out to be a Extremely common thing for RIGHT when the oil light came on. I drove 100ft. The oil could have been a quart low. It was about 800-1000 since the last time i Checked it.
Old 12-03-2012, 07:13 PM   #113
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
The oil could have been a quart low, but you said when you checked it it was "way over" indicating over filled. So where is this oil coming from/going?
And I agree that oil pickup's are on a low side for failure for the most part, but it does happen. I also know that taking action and figuring out/fixing the vehicle the right way before something catastrophic happens is smart.
Old 12-03-2012, 07:16 PM   #114
lvlatthew
Member#: 336712
2002 bugeye wrx
It was way full after I put 2 quarts in without checking Inbetween quarts. I probably only needed one
Old 12-03-2012, 07:50 PM   #115
wagonsarewinners
Member#: 337730
2007 WRX Wagon
Urban Grey Metallic
Just wanted to weigh in on this: I've had my '07 WRX for about 20 months or so, and my oil light went on last night moving it on the street. Stopped the car, checked the oil level and nothing out of the ordinary. Matthew perhaps it WAS the moisture. I'm also in MA and the all-so-useful light was off this morning.
wagonsarewinners is offline   Reply With Quote
Old 12-03-2012, 07:55 PM   #116
lvlatthew
Member#: 336712
2002 bugeye wrx
And the car wasn't started for almost 2 days in the cold and a small amount of snow we had this weekend. So idk. It could've been many things but I'm glad people here gave me the worst case scenario but I don't think my case was to extreme
Old 12-03-2012, 08:05 PM   #117
BluewaterAWD
Member#: 262210
This has all the trimmings to not end well.
BluewaterAWD is offline   Reply With Quote
Old 12-03-2012, 08:53 PM   #118
lvlatthew
Member#: 336712
2002 bugeye wrx
Explain?
Old 12-03-2012, 09:17 PM   #119
Teehsee
Member#: 229300
2011 obp wrx hatch
08 dgm fxt
Originally Posted by Hondaslayer View Post
This.
Or, since the OP JUST BOUGHT THE CAR, the engine bay was probably pressure washed causing the sensor to get moisture in it and turn the O.P light on faintly (as described by the OP)
Subaru tech / service manager for 10 years, wanna guess how many broken pick up tubes I have seen? 1, and it only broke because the oil pan and subframe were nearly sheered off when the driver hit a retaining wall @ 40mph. Broken pick up tubes are not nearly as common as people make it out to be.
That's crazy, I feel like I Hit the powerball twice already.
Teehsee is offline   Reply With Quote
Old 12-04-2012, 05:15 PM   #120
lvlatthew
Member#: 336712
2002 bugeye wrx
And my car just blew up.
Old 12-04-2012, 05:18 PM   #121
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Im sorry, but
Old 12-04-2012, 05:18 PM   #122
lvlatthew
Member#: 336712
2002 bugeye wrx
Im sorry, but
Eh don't worry I'm just messing with you guys. Cars running GOLDEN
The light was on very faintly when I turned my car on. But you can tell it was like a light behind it lighting it up. Car got warm couldn't see anything
Old 12-04-2012, 05:21 PM   #123
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
What?
findurpath is offline   Reply With Quote
Old 12-04-2012, 05:22 PM   #124
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
The light shouldnt be on at all. There is no lights behind any lights on the dash.
Old 12-04-2012, 05:23 PM   #125
lvlatthew
Member#: 336712
2002 bugeye wrx
Read like the 3rd post at the beginning of this post.
That is what happened. Car was cold started it. Could BARELY even see it. 40 seconds later. Not even visible
