Old 12-02-2012, 06:33 PM   #1
sureshot007
Member#: 142405
#716 G2 OBS
Default 2004 FXT Stg2 - help read logs please
Car: 2004 Forester XT 5MT
Mods: Catless up/down pipe, intercooler hoses, perrin aftermaf, panel filter
- I didn't remove the snorkus (the FXT has one, right?), and I haven't touched the wastegate actuator arm at all yet.
Since there doesn't seem to exist a map for the car, I took an 06 WRX Stg2 93oct map and copied/pasted the tables to start with. Did a few 3rd gear pulls. Would anyone be willing to take a look at the logs and let me know if I'm headed in the right direction?
3rd Gear WOT pulls:
https://docs.google.com/open?id=0Bx7...UJaRUltVnQ0Z2M
https://docs.google.com/open?id=0Bx7...GJuLUdKMTFpWWM
3rd Gear Part Throttle pulls:
https://docs.google.com/open?id=0Bx7...Dk2T0hEc0J1N2c
https://docs.google.com/open?id=0Bx7...UNic1hCUDFPUGM
I really appreciate any help and direction you guys can give me on this. I've previously only ever flashed OTS maps and messed with WGDC/Target Boost. Thanks in advance.
sureshot007 is offline   Reply With Quote
Old 12-06-2012, 06:12 PM   #2
soberpoet
Member#: 264784
2003 WRX
Subaru Blue
looking at your WOT logs the second one is what you wanna shoot for for reliability
you can definitely push more boost just be sure that your knock correction isnt pulling timing
11.5 afr is a safe place to be at
theres a sticky in the engine tuning and manegement forum its a guide to tuning i suggest you read it very helpful
soberpoet is offline   Reply With Quote
Old 12-06-2012, 06:59 PM   #3
sureshot007
Member#: 142405
#716 G2 OBS
Thanks for the reply. I've been doing a lot of reading, but I would just like a set of experienced eyes to double check my work.
I adjusted the wastegate arm 3 turns, and tried again. Target boost is 18psi, and I'm still peaking at 12. I'll try adjusting it again, but I might have a boost leak. In my experience, an intake side leak causes it to pull timing, so should I assume if a leak is present, it's on the exhaust side?
Also, I've noticed some low rpm driveability issues. The learning view shows fuel trims under 5%, so I think that's ok, but it does indicate some knock in the 2000rpm/part throttle area. Do I just pull timing from that area of the map?
Old 12-07-2012, 06:18 PM   #4
SubiSam
Member#: 156401
'03 WRB WAGON
2.1 stroker GTX3071R
Yes, just pull a little timing there. Or, there may be a little variation between actual load and indicated load due to how the injectors are scaled and AFR corrected by the MAF scale. Timing just needs to ramp down a little sooner with load. Highlight all the load values and hold the alt key and push ] a few times to increase this value evenly by 1% at a time.
SubiSam is offline   Reply With Quote
