Old 10-24-2012, 03:11 PM   #1
spazsubaru
Member#: 273127
2007 impreza 2.5i
Default after reflash ticking and car wont start
I brought my car to a local tuner to get some codes cleared and to fix some lean issues before emissions and during the reflash his laptop died so we got a extension cord and got it powered again within 5 minutes and it all went through. But now we turn the key to acc and a ticking noise comes from the motor and the car turns over but will not start. hopefully will be finding out today what was wrong (hopefully not a corrupted ecu)
what are your guys thoughts?
spazsubaru is offline   Reply With Quote
Old 10-24-2012, 03:57 PM   #2
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
Well if it died while flashing and you turned the key to off again most likely bricked Ecu. What tuner did you go to so I know not to go to him/her.
freddy121389 is offline   Reply With Quote
Old 10-24-2012, 09:30 PM   #3
spazsubaru
Member#: 273127
2007 impreza 2.5i
forced induction motorsports. :/
Old 10-25-2012, 09:23 AM   #4
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
If your flash fails part way through for whatever reason, you absolutely MUST leave the key on until you can fix the situation and complete the flash. You weren't clear from your post whether you did this or not.
Old 10-25-2012, 09:55 AM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
bricked ecu..
Old 10-25-2012, 10:33 AM   #6
jthatch12
Member#: 321715
03 Big 16G WRX
Seems a little irresponsible that someone would even attempt to flash something with a low battery on their computer. The tuner should've known better.
Old 10-25-2012, 11:25 AM   #7
spazsubaru
Member#: 273127
2007 impreza 2.5i
I've learned my lesson here.
Old 10-25-2012, 02:36 PM   #8
spazsubaru
Member#: 273127
2007 impreza 2.5i
getting a used ecu. should be in 2 days or so, then there installing it and flashing it for free.
Old 10-26-2012, 09:17 AM   #9
jthatch12
Member#: 321715
03 Big 16G WRX
Did they make you buy the ecu?
Old 10-27-2012, 01:39 PM   #10
spazsubaru
Member#: 273127
2007 impreza 2.5i
yes. but not charging me for install or flash. I just need to find the rom
Old 11-02-2012, 12:33 AM   #11
that11guy
Member#: 316149
1998 Legacy
You would think the first thing you do before flashing is make sure you have enough battery life! lol anyhow im guessing all that ticking was your relays going crazy
that11guy is offline   Reply With Quote
Old 11-14-2012, 06:13 PM   #12
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
where are you located... we can unbrick that sucker for you ! pm me for more info!
Bamofo is offline   Reply With Quote
Old 12-08-2012, 03:21 AM   #13
spazsubaru
Member#: 273127
2007 impreza 2.5i
bamfo I'm in connecticut, I already bought a new ecu for my car and its already in and everything is good. the old ecu is sitting in my back seat
