Old 12-02-2012, 08:11 PM   #1
ajshades
Member#: 160255
06 STI OBP
05 WRX WRB
Default Rear rotor stuck/seized
Attempted to replace all four rotors and pads today. Got the fronts done. The backs were not so easy.
So I'm not sure their stock or just cheap rotors form the previous owner but the rears do not have the 8mm small holes to help remove them.
I made sure the hand brake was down, I even clicked the adjuster all the way down, used PB blaster and hit the rotor with a hammer.
It wouldn't budge.
Considering doing something like this on my next attempt:
Thoughts?
ajshades is offline   Reply With Quote
Old 12-02-2012, 09:42 PM   #2
Kingnothing616
Member#: 277507
http://www.mactools.com/shoponline/p...ng-hammer.aspx
Need a bigger hammer... here's what I use.
Kingnothing616 is offline   Reply With Quote
Old 12-02-2012, 11:52 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
a dead blow hammer is a far better choice
http://upload.wikimedia.org/wikipedi...low_hammer.jpg
Old 12-03-2012, 09:33 PM   #4
billyboy999
Member#: 292919
2007 STi
Well considering he's replacing the rotors, I wouldn't worry about using a dead blow hammer to lessen damage, unless there's another reason you suggest using one. The vibrations imparted by a metal hammer may help break it loose better.
billyboy999 is offline   Reply With Quote
Old 12-03-2012, 09:36 PM   #5
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
It wouldn't budge.
Considering doing something like this on my next attempt: Video Link: http://www.youtube.com/watch?v=_-bkb5-A2Qs
Thoughts?
Make sure your emergency brake isn't on.
EDIT: it helps if I read the whole post first. Dead blow.
Psychoreo is offline   Reply With Quote
Old 12-04-2012, 01:30 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
because idiots use the wrong tool for the wrong job
hitting cast iron with a steel hammer is an idiots move
im not an idiot
Old 12-04-2012, 01:42 AM   #7
Kingnothing616
Member#: 277507
Sorry I posted that.. Wouldn't want you guys to hurt your fragile little typing hands with a professionals tool.
Old 12-04-2012, 01:49 AM   #8
lavid2002
Member#: 226864
Just man up and hit the rotor with a mini sledge with all ya got. I like to hit it right at the corner of the hub.
The only thing you have to watch out for is that you don't hit the lug nut studs you will screw up the threads.
The reason they stick is a layer of rust in between the hub and the rotor fuses the two together. It's hard to swing from the inside of the car out so just swing from the outside of the car in. Don't be afraid sometimes you gotta show em who's boss.
lavid2002 is offline   Reply With Quote
Old 12-04-2012, 07:50 AM   #9
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Work smarter, not harder. Use a long bolt and a nut into the caliper bracket attachment points (with the caliper/bracket removed) to press the rotor off.
Old 12-05-2012, 02:36 AM   #10
Haick4
Member#: 339740
We would not worry about employing a dead blow hammer to reduce damage unless there exists another reason you suggest using one. The vibrations imparted by a metal hammer will help break it reduce better.
Haick4 is offline   Reply With Quote
Old 12-05-2012, 08:27 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
and if the rotor chips or shatters and causes collateral dammage such as a cut brake line or abs harness....or maybe your face???
what then???
a TRUE professional would consider this and be smart about it and not let that possibility happen in the first place
also...the vibration that you non-professionals think may be good....may also kill other associated parts and cause other damage
and ive been a licensed A&P mechanic since 1984...so i guess i dont know anything about this
Old 12-05-2012, 11:08 PM   #12
Kingnothing616
Member#: 277507
Didn't know we were spouting off certifications... Recertified ASE Master tech, Toyota factory trained, roughly 3000 brake jobs and alignments under my belt, just to start. Never damaged an abs sensor or brake line in the process. I can only imagine the life you must have working around the .002% chance of come thing that might, possibly, could maybe happen if things go bad. Guess I better not go to work tomorrow, my impact might explode and decapitate a nearby infant.
