Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 12-18-2012, 11:05 AM   #1
Squeakgp
Member#: 300394
2012 WRX STI
Default Weird "whistle" before boost
So, I have been looking for another thread with a description of what I have and I can't find one. So time to post a thread and hope someone with mad search keyword powers doesn't prove me wrong.
So the situation is, I just installed the invidia catless downpipe. I have the factory midpipe and a custom muffler delete. Only other thing I have done is that I removed the intake silencer. Now, during install I did take the IC off but I have rechecked all the hoses. As far as I can tell they are on fine. The real problem with finding this sound is that I really only hear it under load. So revving it with my head under the hood doesn't get the same sound. Also the sound is most prominent pre-boost. Im not sure if the turbo/exhaust drown out the noise while in boost, but it seems to not be there.
Any ideas??
Squeakgp is offline   Reply With Quote
Old 12-18-2012, 11:19 AM   #2
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
Are you sure it's just not the turbo spooling up? You DID remove the intake silencer...
Did you ask Bub-rub?
findurpath is offline   Reply With Quote
Old 12-18-2012, 11:21 AM   #3
microsnook
Member#: 313952
2006 STi
SGM
Its probably normal. I have an aftermarket intake (no silencer) and it makes a whistle before I boost too. I love it! Just more noises.
microsnook is offline   Reply With Quote
Old 12-18-2012, 11:50 AM   #4
Squeakgp
Member#: 300394
2012 WRX STI
I'm really not sure if it shouldn't be there. I don't hate the noise, I was just worried it was bad...
Old 12-18-2012, 12:32 PM   #5
eronenris
Member#: 262992
2009 wrx
pearl white
2008+ don't have intake silencers...
eronenris is offline   Reply With Quote
Old 12-18-2012, 12:35 PM   #6
Squeakgp
Member#: 300394
2012 WRX STI
STI's do...
Old 12-18-2012, 01:09 PM   #7
eronenris
Member#: 262992
2009 wrx
pearl white
Originally Posted by Squeakgp View Post
STI's do...
oh sorry, i misread thought you had a wrx.
Old 12-18-2012, 02:25 PM   #8
RoadKillDMD
Member#: 284792
2011 STI
Plasma Blue Pearl
You did an intake 'silencer' delete, and now you're why it's making whistling noises? Sounds like you didn't do much research before diving into something that you know nothing about... Don't do that. Research THREE times BEFORE modding.
Now, to ease your mind a little, the sound is completely normal. Nothing to worry about, as long as all of your boost and vacuum lines are secure and the whistling isn't a boost leak.
RoadKillDMD is offline   Reply With Quote
Old 12-18-2012, 02:56 PM   #9
Squeakgp
Member#: 300394
2012 WRX STI
The silencer delete was done well before the downpipe. I am very familiar with the normal turbo spool/BPV sound associated with the delete. I like that, hence why I did the mod. This sound was in addition to what I was hearing before. I'm hitting target boost, maybe even have a bit of boost creep, and once again the sound is heard while accelerating but when staying out of boost.
Why is it that 80% of the population on here want to bash first before providing any real help??
Old 12-18-2012, 03:00 PM   #10
99imprezd
Member#: 198964
2004 WRX wgn, built!
Prob normal.. should be loud and whistly.. more power means more noise. lol.
99imprezd is offline   Reply With Quote
Old 12-18-2012, 07:48 PM   #11
n0t an sti
Member#: 309488
2012 Impreza WRX
My car does the same thing, kind of sounds like a popped balloon rushing noise? I dont have any boost leaks but i do have an invidia catless dp and stock intake
n0t an sti is offline   Reply With Quote
Old 12-19-2012, 09:56 AM   #12
myblusti
Member#: 337871
2010 5-door STI
blue/gold
at what rpm are you hearing it? for example. ( when im driving in 4th and im at 2k and i punch it i hear this whistle noise about .5-1k rpm's before i feel boost.) if this sounds like your issue. this is completely normal. and you should probably downshift in this situation to prevent overboost.
myblusti is offline   Reply With Quote
Old 12-20-2012, 11:07 AM   #13
Squeakgp
Member#: 300394
2012 WRX STI
It happens in almost any gear during light acceleration, in the 1-3500 rpm range. I don't have a boost gauge, but I do have the AP, and looking at that while accelerating I stay in the negatives when I hear this noise.
Old 12-20-2012, 11:37 AM   #14
99imprezd
Member#: 198964
In my 04 wrx w/ invidia catless, and perrin catless up-pipe it definitly is way louder than stock.. The sound of rushing air blowing through the dp is crazy. almost sounds like it raining really hard and a little bit of a whistle.. lol. I did have some much louder whistling that turned out to be a bad seal between the Blow off valve and my top mount intercooler whch is common for these to leak, although it didnt effect my performance at all was annoying as hell.. If you think its louder than it should be and have messed with any of the hoses to the blow off or turbo inlet, double check for leaks.. even a small one will make one hell of a ruckus..
Old 12-20-2012, 12:14 PM   #15
Squeakgp
Member#: 300394
2012 WRX STI
I was starting to wonder about that piece as well. Was your leak enough to feel with your hand or did you have to do something else to find it?
Old 12-20-2012, 12:34 PM   #16
99imprezd
Member#: 198964
heres a vid to how I found my leak at my BOV.. you could do the same thing without disassembly prob for individual hoses etc.. was only using about 20psi in my compressor..
http://s829.beta.photobucket.com/use...rleak.mp4.html
Old 12-20-2012, 03:30 PM   #17
WRXSteye20008
Member#: 175565
2005 STI CGM
Built 351whp/368tq
Fantastic reference, I knew exactly what you meant when you said it. For those who don't.
OP take a video of the sound it could be a million sounds and from what you are describing sounds the the silencer delete however we have no idea. Make a video and post it so we can better help you, otherwise it could be anything. My bet it is the turbo spool you are hearing the the silencer not there as it does make it a bit louder. Everyone on here who has the silencer delete, took it out, we know what it sounds like.
WRXSteye20008 is offline   Reply With Quote
Old 12-20-2012, 04:21 PM   #18
Squeakgp
Member#: 300394
2012 WRX STI
Oh lol, I didn't catch that reference. I have however seen that awesome video before. I will try and take a video but I have a feeling the microphone will mostly pick up my exhaust, it's kinda loud.... We will see
Old 12-23-2012, 09:41 PM   #19
Bryan18
Member#: 141238
2006 STi
Crystal Gray Metallic
Sounds like a boost leak...i had the same sound after a bov install. The gasket on the bov had a slight tear in it
Bryan18 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 09:25 AM.
