![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 309439
NESIC
Vehicle:2006 Impreza 2.5i |
I just had my front sway bar links and bushings replaced, new tires, than got my alignment. Car pulls to the right, if going like 70mph pulls considerably. The print out showed everything was in alignment. The steering also seems little more loose. Could it be the new tires needing to be kind of broken in? Or from somewhere I read, maybe the toe is still outa wack? Thanks for you help !
#2 |
Member#: 254851
Vehicle:2002 Wrx wagon 5mt PSM |
Alignment is probably not right.
Can you show us the alignment sheet? Where was it done, a chain tire/ sears type place? |
#3 |
Member#: 309439
NESIC
Town fair tire..
#4 |
Member#: 37359
Vehicle:2003 WRX |
Sounds like you mean, if you take your hands of the wheel, the car starts moving to the right.
If the alignment is not an issue, check tire pressures. Did you change from a generic type tire to a performance tire? Some will follow road irregularities much more - it's called tramlining - and road camber can also effect them more. Shouldn't be as bad as you describe though. |
#5 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
bad tire.....likley
#6 |
Member#: 309439
NESIC
No just got regular a/s tires. The tire pressures are spot on. To pulls on new smooth tarmac on the highway that was redone about 2 months ago, and pulls the same on the regular highways, that are much older.
#7 |
Member#: 16200
post the alignment printout
and if you have a bad tire it can make it pull |
#8 |
Member#: 309439
NESIC
I will post it up tonight and my tires are maybe 100 miles old and I know that doesn't mean that I couldn't have a bad tire
#9 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Could be bad tires or alignment. Even if the alignment sheet says everything is good it doesn't mean there wasn't a problem with the procedure that can cause the car to drive poorly. You could swap the front tires and see if the car pulls the other direction. Otherwise I would take it back to them.
Tony |
#10 |
Member#: 309439
NESIC
Well tomorrow I'm going to have my sway bar links and bushings doubled checked and tightened, rebalance the wheels than redo the Alignment.
