Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 12-03-2012, 05:35 PM   #1
datzun90
Member#: 331317
Default Wagon w/ STi suspension Camber Issues
Hey Everyone, I just recently finished putting a complete '04 STi suspension in my '05 2.5 RS wagon. The rear went together perfectly and I have just a slight amount of negative camber. However, when it comes to the front I have some issues. I used 04 STi front LCA's and 04 STi front struts with 07 WRX sedan knuckes. However, no matter what I do it looks like I have .5 - 1 deg positive camber on the driver's side and like 5 deg on the passenger side. I realize the right side is totally out of whack but I figured that with the driver's side I should be able to get a small amount of negative camber. I think maybe both of the knuckles I bought are wrecked. I just wanted to make sure I didn't miss something, was I supposed to use the wagon knuckles even though I used sedan arms and struts? Should this setup allow me to get at least a little bit of negative camber (like -.5 deg). I have included a few pics below and these are what the wheels look like with the camber bolts fully maxed out. Its hard to tell in the first picture but the wheel has slightly positive camber ( I figured with stock bolts I should be able to get a least a little bit of negative camber up front)
I apologize if this has been covered before but its a bit of an emergency seeing as I need to get this on the road ASAP. Thanks for all of your help.
datzun90 is offline   Reply With Quote
Old 12-03-2012, 05:50 PM   #2
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Yeah, something is bent, likely the upright. If the strut was that bent you would be able to tell just by looking at it.
The knuckles are the same between sedan, wagon, and 04 sti so you didn't need to change them for the struts to work.
jamal is offline   Reply With Quote
Old 12-03-2012, 06:11 PM   #3
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Put your old knuckles on. Unless they were damaged, they will work just fine.
Bikelok is offline   Reply With Quote
Old 12-03-2012, 06:13 PM   #4
Bikelok
Member#: 254851
2002 WRX wagon 5mt
If it still is not right after doing that then something else is bent.
Old 12-04-2012, 11:16 AM   #5
datzun90
Member#: 331317
Both ball joint pinch bolts broke off in the spindles so instead of trying to get them out I figured I'd get some nice used ones.
Old 12-04-2012, 12:52 PM   #6
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Then drill out the broken bolts or get better knuckles.
Old 12-06-2012, 09:35 AM   #7
datzun90
Member#: 331317
Thanks for all of the feedback guys. I went and got another set of knuckles yesterday. I'll give them a try today and see how it looks.
