Old 12-03-2012, 08:32 PM   #1
JSti07
Member#: 190019
07 STi
swp
Default JSTi's 07 SWP STi Motor build underway! Sleeves and long rods :)
Well here she is, I figured I would post up a thread here on nasioc so I can get some constructive criticism and some feedback on what I have going on with the car.
Anyhow, I have a 2007 STi with just passing 14,000 miles. I got the car with 7,000 miles and bone stock and I have been building it since. I have just recently (within the past year and a half) have found a passion for autocross and track days, so this is the route I have decided to take my car down. It still spends some time around on the street though
JSti07
2007 Satin White Pearl STI
Mods to date..
Tuned on Cobb speed density by Nate Silveri at TPG tuning
Engine
*Now on E85!
-Darton sleeves
-O-ringed
-JE forged pistons 99.5mm CR: 9.0:1 (coated, Tool Steel Wrist pins)
-Maxwell power H-beam long rods +2mm
-King XPG extra clearance
-Crank: nitrated crank
-ARP custom age 625 Headstuds
-Heads ported (done by Curt Brown)
-Custom headgaskets
-GSC S2 cams
-STD size Super alloy valves
-GSC Beehive spring and retainers
-Gates Timing belt
-Motive Composite TGV deletes
-Stock STi 10mm oil pump
-Killerb oil pickup & baffle
-LGT/wrx plastic manifold (reversed)
-Ported WRX throttle body
-ACT XT-SS clutch
-ACT Streetlite flywheel
-Koyo Vh091672 Radiator
-AMS GT3076 rotated turbo kit
-Tial .82 hotside
-Tial 44mm wastegate
-Custom TPG Intercooler piping
-4" intake
-Litespeed UEL header
-Perrin FMIC core (Silver)
-Cobb accessport V2
-Blitz Nur Spec R catback exhaust (removed taper)
-Hallman Pro RX MBC
-Tial BOV
-IAG AOS
-ss power steering line
-Dei titanium heat wrap (Up pipe, Header, Downpipe, Ewg dump tube)
-Painted engine bay caps
-Braille 15 lb battery
-NRG hood struts
-KSTech air pump delete block off plate
-PTP T3 turbo blanket (silver)
-NGK one step colder plugs
-GM air intake temp sensor
-Omni 4bar MAP sensor
-MAF sensor block off plate
-IAG ewg up pipe
-Peterson catch can
-Tial 38mm MV-S with 1 bar spring
-Synapse synchronic bov
-Grimmspeed VF series IWG bracket
-Cobb SF intake
-Invidia V2 catless downpipe
-Aquamist HFS-6 Meth kit
-Stock BPV
-MAC valve (allows use of aquamist failsafe with MBC)
-Coolingmist CMGS-FS meth kit
-Ultimate Racing up pipe
-Ultimate Racing flex dump tube
Fueling
-Injector Dynamics 1300cc injectors
-Radium Engineering 2x Walbro 255 pumps
-Radium Engineering surge tank
-Russell "Pro Classic" -8 & -6 Fuel Lines
-Fuelab Fuel Pressure Regulator
-Fuelab fuel filter
-Cosworth Top-Feed Fuel Rails
-Walbro 450lph (in tank)
-STM battery re-wire kit
-Walbro 255lph fuel pump
-Injector Dynamics 1000cc injectors
Fluids
-Brad Penn 15W-40
-Purolator PureONE filter
-Shell Rotella T6 15W 40
Heat Shielding
-Turbo blanket
-Thermotec copper exhaust wrap on dp
-Cobb Turbo Heat Shield
-DEI Cool Tape on shield and intercooler
Drivetrain
-TiC super shifter set
...TiC STi Shift Linkage Bushings
...Kartboy Front and Rear Shifter Stay Bushing
...Kartboy Shifter Lever
...Pivot bushings
...Pivot bushings
-TiC rear diff bushings
-TiC outrigger bushings
-TiC subframe bolts
Suspension
-Racecomp Engineering Tarmac 2 coilovers
-Swift 9k 6" front springs
-Swift 8k 7" rear springs
-Hyperco helper springs
-GTWORX camber plates (front/rear)
-Custom X-brace
-RCE yellows
Exterior
-HKS Kansai Diffuser
-Tint on rear windows (not sure what %)
-Debadged all but sti and center Subaru logo
-05 Tails
-WRC tail light mod
-Blacked out headlights
-Chrome indicator bulbs
-Chrome front and rear turn signal bulbs
-White STi fog light cover stickers
-Passenger fog light bezel
-Custom DIY Front air splitter (for autocross/track use)
-Baysonr front lip painted satin black
Interior
-Sparco EVO II blue
-Sparco bracket
-Sparco sliders
-Sparco side mounts
-blacked out:
*black microfiber suede headliner
*pillars
*visors
*dome lights
-Nardi Personal Neo Grinta 350mm steering wheel (black leather)
-NRG quick release
-Works Bell hub
-Teamtech silver 3" harness
-Autometer Elite series vac/boost gauge
-Autometer Elite series oil pressure gauge
-Autometer Elite series oil temperature gauge
-Sparco Harness bar (painted honda gray metallic)
-Clarion MAX385VD head unit
-Blacked out center dash, vent rings, polished shift trim
-ATI gauge pod
-Type S universal holder (use for accessport)
-AEM digital Boost gauge
-AEM digital Oil Pressure gauge
-Aquamist meth flow gauge
-JL audio 12" W7 with ported box
-Hifonics 1200w amp
Wheels and Tires
TRACK
-Enkei RPF1 17x10
-Toyo R888 275/40
STREET
-Enkei RPF1 black 18x9.5 +38
-8mm spacers for front
-ARP extended studs
-Project Kicks neo chrono R40 lugs
-255/35 Star Specs
-Fenders rolled and pulled
-Konig Hotswap black 18x8 +40
-Falken 225/40/18
Weight Loss
-Removed spare tire and jack
-Removed Oh S*** Handles and brackets
-Air pump delete
-Removed all back seat seat belts and supporting hardware
Waiting to be installed/ On the way
Red- for sale/ sold
Green- removed
Latest Test Results
...compression.. Leakdown
JSti07 is offline   Reply With Quote
Old 12-03-2012, 08:33 PM   #2
JSti07
Member#: 190019
07 STi
swp
When it was brought home:
Autocross:
Old 12-03-2012, 08:33 PM   #3
JSti07
Member#: 190019
07 STi
swp
Old Graphs:
DO NOT HAVE PLOT OF MOST RECENT SETUP...
**TPG Tuning low reading Mustang Dyno**
Old 12-03-2012, 08:34 PM   #4
silverwerx
Member#: 81246
. .13 EVO X MR
.03 Cosworth Wrx, 14 Jeep
clean
silverwerx is offline   Reply With Quote
Old 12-03-2012, 08:53 PM   #5
Il Capitano
Member#: 299619
2011 Evo X
WW
Very nice
Il Capitano is offline   Reply With Quote
Old 12-04-2012, 02:13 AM   #6
WhozNext
Member#: 265369
07 STI
Looks awesome. You didn't have no issues with that front mount clearing your bumper for fitment?
WhozNext is offline   Reply With Quote
Old 12-04-2012, 03:59 AM   #7
frozie
Member#: 215927
05 JDM Swapped
V8 Spec C EJ207
love your car. Got any more shots of the rear end?
frozie is offline   Reply With Quote
Old 12-04-2012, 09:10 AM   #8
TPG Tuning
Member#: 185725
Beautiful car as always Jeff!!
Nate
TPG
TPG Tuning is offline   Reply With Quote
Old 12-04-2012, 10:41 AM   #9
JSti07
Member#: 190019
07 STi
swp
You have to cut the front bumper to get it to fit. It's not hard, just time consuming if you want to make it good. Here are some pictures to give a better idea on what you have to cut.
Old 12-04-2012, 10:42 AM   #10
JSti07
Member#: 190019
07 STi
swp
Old 12-10-2012, 03:48 PM   #11
JSti07
Member#: 190019
07 STi
swp
Just so I don't forget
Old 12-10-2012, 06:38 PM   #12
kyle sti
Member#: 157718
07 SWP STi
WFC OG #036
is that a ravspec diffuser?
kyle sti is offline   Reply With Quote
Old 12-10-2012, 07:27 PM   #13
07SWPSTi
Member#: 158960
07 Impreza STi
07SWPSTi is offline   Reply With Quote
Old 12-10-2012, 07:48 PM   #14
JSti07
Member#: 190019
07 STi
swp
It is. Found it for a good deal so I picked it up to cover my burnt bumper.
Old 12-10-2012, 08:12 PM   #15
Gendy
Member#: 261613
09 WRX
Beautiful, i bet its a blast to autox
Gendy is offline   Reply With Quote
Old 12-10-2012, 08:52 PM   #16
BoostnBooze
Member#: 183403
2007 WRX
tastefully done, my fav diffuser. What's are the benefits of a rotated kit?
BoostnBooze is offline   Reply With Quote
Old 12-10-2012, 10:28 PM   #17
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
.63 or .82?
Is there major turbo lag?
Excision is offline   Reply With Quote
Old 12-10-2012, 11:44 PM   #18
JSti07
Member#: 190019
07 STi
swp
Sure is!
Thanks. A rotated kit helps with the fitment of larger turbos. Some people have seen a slight increase in spool, but with the innovations of the new stock location turbos, such as the atp30r and the blouch xtr series just to name a couple, they are able to achieve the power of rotated kits with maybe a psi or so more of boost.
Originally Posted by Excision View Post
.63 or .82?
tial .82. For the turbo size, the car responds exceptionally well. I haven't been in many other stis with rotated kits (none actually) but many people who have been in my car have been exposed to cars similar to mine and they always mentioned that the response of my car is like none they have ever experienced. I say this honestly, not trying to boast.
As you can see in the dyno sheet, the car is very responsive and a good match for my driving style. Just wish I was able to upgrade my internals so I could make the most of my set up, I'm sure there is plenty left on the table.
Old 12-11-2012, 06:14 AM   #19
Decker39
Member#: 257107
2002 WRX Wagon
Sick car man! I'm down in Warren and also got tuned by Nate. You should head down sometime and see the new TPG shop. I'll be seeing you in the spring hopefully as I'd like to come up and hang out with you Misery Bay boys for some autocrosses once the snow clears. Keep up the good work man.
Decker39 is online now   Reply With Quote
Old 12-11-2012, 11:18 AM   #20
JSti07
Member#: 190019
07 STi
swp
Thanks man. Ya I am hoping to make it down to the new shop soon for a visit, anxious to see how the shop came out.
Old 12-11-2012, 11:51 AM   #21
Decker39
Member#: 257107
2002 WRX Wagon
Hit me up if you head down that way, maybe I'll make a trip down also...don't find too many guys around this area who are actually building subaru's the right way unless they live in the Burgh.
Old 12-11-2012, 05:18 PM   #22
runningonE
Member#: 340294
Your car is tits my friend!!!
runningonE is offline   Reply With Quote
Old 12-11-2012, 07:04 PM   #23
sotoWRX
Member#: 186202
06 WRX
Dom3 XT-R
Awesome !
sotoWRX is offline   Reply With Quote
Old 12-11-2012, 08:46 PM   #24
JSti07
Member#: 190019
07 STi
swp
Will do. I'll send a pm your way right now.
I'm thinking of going maybe during the first week of January, but I'm not sure yet. Just FYI the car is in winter storage so it won't be making the trip.
Originally Posted by sotoWRX View Post
Awesome !
Thanks!
Old 12-11-2012, 08:49 PM   #25
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
nice! looks great. keep up the good work
VTSubieRS is offline   Reply With Quote
