Old 11-28-2012, 04:48 PM   #1
ctfjr
Member#: 297540
2011 STI
Default Any benefit to Grimmspeed crossover with ELH?
I have the Invidia ELH installed and have been considering the ported Grimmspeed product. Not being one much for just adding 'stuff' without some tangible return, I don't know if the benefits of the larger crossover pipe are there for ELH's. . .
Does anyone have any experience here?
ctfjr is offline   Reply With Quote
Old 11-28-2012, 04:53 PM   #2
littlewhitewagon
Member#: 103068
11 STI sedan
You're funny. Where would you put that pipe since your stock exhaust manifold is not attached to your car?
littlewhitewagon is offline   Reply With Quote
Old 11-28-2012, 05:17 PM   #3
ogboot
Member#: 170906
psm
Stock header is a 3-piece, that's why you can add-in the grimmspeed piece. It goes in the middle, between the collectors. You've gone a totally different route, can't be installed.
ogboot is offline   Reply With Quote
Old 11-28-2012, 06:10 PM   #4
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Yeap your aftermarket header replaces the oem system. Our cross pipe is to be used with the OEM manifold ends so your set up will not be compatible with this part.
Mike
GrimmSpeed is offline   Reply With Quote
Old 11-28-2012, 06:35 PM   #5
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
Where would you bolt the crossover pipe when you already have a header?
findurpath is offline   Reply With Quote
Old 11-28-2012, 07:46 PM   #6
Rodwrx23
Member#: 170948
You should sell me your Invidia EL header for $350 and buy Grimmspeed's setup. Then we'll both be happy
Rodwrx23 is offline   Reply With Quote
Old 12-11-2012, 10:59 PM   #7
03subyR
Member#: 182647
2003 WRX
Sonic Yellow
Weld it in
03subyR is offline   Reply With Quote
Old 12-11-2012, 11:08 PM   #8
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I don't even...
