Notices
Old 01-06-2013, 06:38 PM   #101
Tyler2012WRX
Member#: 309601
2013 STi
Satin Pearl White
Your car is seriously sweet.
Where did you order your side skirts?
Tyler2012WRX is offline   Reply With Quote
Old 01-06-2013, 07:17 PM   #102
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
A couple post above yours he says where he gets all his JDM/Imported parts.
Originally Posted by FLEX'N WRX View Post
There is a contact that I use located overseas. None of the US distributors offer the S206 exhaust or Subaru Meter Set: gauges. Most smaller items/accessories are available in the states and are easily attainable.
They can be found at Japanparts.com or RSD HERE.
Not cheap, but quality costs $$$.
Again Flex, love this set up. I just spent a few minutes photoshopping your wheels/brembos on my hatch and blacking out the roof. It's a solid setup and gives me an idea of where to go with my build. (Don't worry I won't copy too much )
JSchell1309 is offline   Reply With Quote
Old 01-06-2013, 08:05 PM   #103
FLEX'N WRX
Member#: 163672
GV
Same color as veneers
Originally Posted by mickav6 View Post
is the top painted or is it vinyl?
Gloss vinyl
Originally Posted by scby rex View Post
Did you have to special order those wheels in 5x100? Nice all around.
Short answer: No
Volk/Rays are manufacturing 5x100. Mackin Industries receieved the first batch last summer then allocated a certain amount of the wheels to go to authorized distributors. Issue was a majority of the 5x100 were staggered setups for the BRZ/FRS. Apparently only 9 sets of 4 (36 wheels) in semi-gloss black 18x9.5 +40 came in last summer. Black, Silver, Matte Graphite, and Blue are all now showing up. It's locating full sets of 4, the color you want, and the wait for them can be irritating.
Your car is seriously sweet. Where did you order your side skirts?
The places mentioned above by others are reputable options.
FLEX'N WRX is offline   Reply With Quote
Old 01-07-2013, 07:12 PM   #104
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Thats what I figured on the wheels, frs rear fitment. They look awesome though.
scby rex is offline   Reply With Quote
Old 01-17-2013, 03:45 PM   #105
Bizborky
Member#: 337362
2013 WRX
I don't know of it has already been asked. But where can I get the Subaru/Defi gauges you have. I am very interested in picking up a set. Thank you and beautiful WRX!
Bizborky is offline   Reply With Quote
Old 01-17-2013, 10:13 PM   #106
FLEX'N WRX
Member#: 163672
GV
Thanks. The question has been asked. Based on references the best bet to use as an overseas vendor is japanparts. IWSTI members used jp for the gauges and had good dealings.
The gauge set is perfect if there's an OCD factor to the color scheme. Defis aftermarket lineup is top tier. Mechanically, I couldn't find much difference with Defi's aftermarket units and the red face is still a perfect match. The units, needle and SUBARU are the differences on the faces.
Old 01-17-2013, 10:20 PM   #107
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
The exhaust was an axleback only or whole STi 206 exhaust? The more i see your car, the more i.reconsider racking up my cards and future tax returns
Subie FA20 is offline   Reply With Quote
Old 01-17-2013, 10:33 PM   #108
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Great work man!
Smurftastic is online now   Reply With Quote
Old 01-24-2013, 01:36 PM   #109
2011mwgwrx
Member#: 300784
2011 WRX Limited
hmmmmm i see a VF52 for sale. Plans
2011mwgwrx is offline   Reply With Quote
Old 01-29-2013, 03:17 PM   #110
FLEX'N WRX
Member#: 163672
GV
Old 01-29-2013, 03:46 PM   #111
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
How much fun was that to install?
xluben is offline   Reply With Quote
Old 01-29-2013, 05:07 PM   #112
J_Maher_WRX
Member#: 290307
I think the Perrin one isn't as bad as the hard ones like the AMR or AP, still probably a tricky install tho
J_Maher_WRX is offline   Reply With Quote
Old 01-29-2013, 05:24 PM   #113
FLEX'N WRX
Member#: 163672
GV
not too difficult...
Old 01-29-2013, 08:27 PM   #114
2011mwgwrx
Member#: 300784
2011 WRX Limited
what did you remove. I am talking about the piece in the bottom right near the alternator cover piece
Old 01-29-2013, 08:31 PM   #115
FLEX'N WRX
Member#: 163672
GV
The air pump has been removed. Cosworth plates used for the delete.
Old 01-29-2013, 08:40 PM   #116
2011mwgwrx
Member#: 300784
2011 WRX Limited
really cleans things up
Old 01-29-2013, 09:29 PM   #117
Scnsaracer
Member#: 319511
2013 STI Sedan
Ice Silver Metallic
Hey Flex - what is benefit of removing the air pump?
Scnsaracer is offline   Reply With Quote
Old 01-29-2013, 09:32 PM   #118
TimStreetmasters
Member#: 322499
2011 WRX
is your VG an SPT part or another brand? In the pics it looks as if your VG goes perfectly from molding to molding. From other pics that I have seen of the product, their are usually gaps between the VG and the moldings
TimStreetmasters is offline   Reply With Quote
Old 01-29-2013, 09:45 PM   #119
FLEX'N WRX
Member#: 163672
GV
Reasons for this removal are commonly weight savings(~10lbs) or more often to accommodate turbos with larger compressor housings (Removing the secondary components on the passenger side). Only item retained is the barometric pressure sensor.
Since you are believing that it goes from molding to molding, then I have succeeded.
The VG is SPT. Color matching the VG and using the vinyl helped achieve this illusion of a complete piece.
Old 01-30-2013, 04:39 AM   #120
FLEX'N WRX
Member#: 163672
GV
The changes relevant to the pics above are the 3" Perrin inlet, air pump removed, COBB EWG bracket installed, and Process West standard compressor outlet silicone hose. All relative to the main upgrade...
Blouch Dom 1.5 XT-R
- 10cm housing
- 3" Compressor Inlet
1st Posts Updated.
Old 01-30-2013, 07:52 AM   #121
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
Looks great man. Every time I looked in the engine bay, I wanted to remove that air pump.
dcorn is offline   Reply With Quote
Old 01-30-2013, 10:58 AM   #122
BrendanTheGreat408
Member#: 271207
2011 WRX
God droooooool probably one of my favorite ever builds
BrendanTheGreat408 is offline   Reply With Quote
Old 02-01-2013, 02:21 PM   #123
06AWD
Member#: 112843
2011 SWP STI Sedan
Speedline/RCE/Cobb
PM'd you about your exhaust. Order info would be great if you'd like to share. Thanks!
06AWD is offline   Reply With Quote
Old 02-01-2013, 03:04 PM   #124
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
That turbo sucks. I don't know why you would ever want to bolt one of those on your car.
rsutton1223 is offline   Reply With Quote
Old 02-01-2013, 03:33 PM   #125
FLEX'N WRX
Member#: 163672
GV
Know what sucks Robb... A Borla header Greddy Elite exhaust revving, Perrin intake sucking, 1.5 XTR spooling , 400whp WRX with thousands investeded in AUDIO equipment.
Ive received no such thing.
