Old 09-12-2002, 09:50 PM   #1
GTKim
Member#: 22609
Unhappy Engine Oil leaking....
Hi~ My dear Subaru Owners..
Please help me because I have some problems in my WRX 2002.
Actually, I have changed Engine Oil of my WRX about
one month ago at one Subaru dealer near my house. But I
cannot help but to change my engine oil again because all of the
engine oil was leaked out. (I found this
problem by the warning sign of engine oil pressure check)
I heard that former dealer staff who changed engine oil may
made a mistake and did not thight bolt after oil change.
In another dealer, I already checked engine and heard that there
was no problem. I felt this Subaru dealr is totally different
compared with the former dealer. Service is very excellent.
But they told me that they could not disassamble and
check inside of engine. All of the works they did check engine
sound and computer-scanning check.
Please let me know how I can check inside of engine more
detailly again as soon as possible.
I trust the expertise of Subaru dealer and trained
technicians who inspected, diagnosed, and repaired my WRX
a few days ago.
But I need more detailed and specific check again.
I am really worried and if you give me a good advise.
Thank you
GTKim is offline   Reply With Quote
Old 09-12-2002, 10:09 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If the oil pressure warning light came on while you are driving this is very bad. The sensor switch for the light is set to close at about 2.5 psi of oil pressure which is essentially nothing. If there was so little oil in the motor that the pressure dropped enough to turn on the light, and you drove it this way for any length of time, it is very likely that the engine was damaged. The fact that you are now hearing knocking confirms this. The presence of knock should be an indication to the dealer that it is now necessary for them to tear down the engine.
You should not drive the car any more as this will only make things worse.
The most important thing to do is document what you have just said as much as possible with regard to the fact that the loss of oil was caused by the incompetence of the dealer's employee. Get as much as you can in writing, and get the Subaru field rep involved if necessary.
From what you are describing there is a good possibility that your car will need a new engine and you want to be sure that it is covered under warranty since it was not your fault.
You may share a small part of the responsibility here since that much of a leak could have been noticeable (they may try to bring up this point), but on the other hand you would not expect something like this to happen on a brand new car so you would not have been expected to look for it or check the oil.
Good luck-
Old 09-12-2002, 10:15 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Before you do anything I think you should contact SOA. Tell them your exact story so that they document it. Tell them you are afraid to visit the same dealer again because they may cause additional damage.
Old 09-13-2002, 11:45 AM   #4
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
And FWIW, Subaru of America is here
jblaine is offline   Reply With Quote
Old 09-13-2002, 08:09 PM   #5
fpa1974
Member#: 15371
2002 WRX Sedan(gone)
Pearl Blue
Can you tell us which is the bad dealer and which one is the good one. I am really interested to find a nice dealer in Atlanta since I had my share part of dealer 'competence' around here.
And like the others said. Make sure you document everything with Subaru. If not you might be in for a bad surprise.
Good luck with getting your issue resolved!
Florian
fpa1974 is offline   Reply With Quote
Old 09-14-2002, 02:10 PM   #6
GTKim
Member#: 22609
Default Trust worth dealer
Thank you for your concern and kind advice~
Yesterday, when I asked about the problems (Oil leaking) of my car, former dealer did not admit their fault even though Oil filter and oil drain plug left loose and this was the reason of leaking.
I am very upset but I will not mention the name of this dealership because I don't want to do harm for this dealer. Also, reason of Oil filter and oil drain plug left loose would, maybe, was not their fault. I should have checked my oil everyday for the problems.
Service manager just told me that "Don't worry, you have warranty. You know what is warranty?(Absolutely I know -_-) you can change oil again...."
Anyway, I will not go this dealer anymore. I don't want to check my car at there and I went to another dealer, SUBARU of Gwinnett which checked, drained and added 4 quarts of oil a few days ago.
Service manager SUBARU of Gwinnett heard about my problem more carefully and recommended me to give them more times to check more specifically and detailly. I accepted her recommendation and left my WRX in SUBARU of Gwinnett.
Frankly speaking, as you know, I am an international student and my english standard is not good. that's why I feel more difficulty.
SUBARU of Gwinnett is really trust worthy, I am sure.
Also, Subaru parts department have so many subaru accessaries.
(I bought Pink I emblem and I will STi cloths in there.)
I will go there Wednesday, next week.
p.s. Are you Georgia Tech student? Florida license plate, Blitz muffler....
Florian
Old 09-14-2002, 02:18 PM   #7
GTKim
Member#: 22609
I printed out your specialized explanation about Oilleaking problems and submitted to Subaru dealer.
They will check my car until wednesday without changing engine. After that I will decide to complain officially and document all of my experience or not.
I really hope there is no problem in my WRX engine and if technician will find some problems, I will follow your advice.
Your comment and explaination really helpful for me to solving the problems of my WRX and much much thank you for your concern and kindness!!!!!!!!!!!!!!!!!!!
Thank you
Good luck-
Old 09-15-2002, 02:40 PM   #8
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
I hope that your engine turns out OK. If it does not, it is very important to document in writing as much as you can, even if it is just writing down in your notebook who did what, who you talked to, what date & time, what they said, etc. If you write all this down as it is happening (a "contemporaneous record"), then you will have less difficulty in getting warranty repairs later.
Old 09-15-2002, 06:03 PM   #9
fpa1974
Member#: 15371
Pearl Blue
Default Re: Trust worth dealer
No. Not really. I will be going to Georgia Tech next fall though for my master degree.
For the moment I live and work in Dunwoody Area as a Software Engineer.
The reason why I asked about your dealer experiences is that I had extremely bad luck at one place I do not want to mention here. Anyway check your email and good luck with your car.
Florian
Engine Oil Leak Poo Vancouver Impreza Club Forum -- VIC 14 03-03-2005 02:02 AM
Engine Oil Leak b.rowe Mid West Subaru Owners Club Forum -- MWSOC 4 12-01-2004 06:46 AM
1.8L FWD engine oil leak yimmer Normally Aspirated Powertrain 15 07-17-2004 04:08 AM
Engine Oil Leak ? JAnderson Normally Aspirated Powertrain 2 04-28-2002 07:40 PM
Engine oil leaking into transmission bmacauto Normally Aspirated Powertrain 5 02-23-2002 04:00 PM
