Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 12-04-2012, 05:08 PM   #1
Member#: 333285
Default turbo cams in non turbo head?
would cams meant for a turbo engine work in a non turbo head (for a turbo setup)? like if i got ej25d heads or dohc rs heads, would i be able to use sti cams or aftermarket cams made for sti? i also understand the avcs delete aspect, just want to know what the cam options are if i ended up using those other dohc heads instead of sti heads.
opey is offline   Reply With Quote
Old 12-05-2012, 02:51 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Non turbo heads have a different sized journal, so no they won,t work. Delta does a cam that will work on a turbo engine.
Old 12-05-2012, 07:57 PM   #3
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
IIRC, EJ20h/k cams will work in EJ25D heads.
