Old 12-05-2012, 02:26 AM   #1
lccl
Member#: 210295
Default 1/2 dash lights out
The light behind the fuel gauge went out, and then later about 1/2 the light behind the tach also. I'm having trouble finding a thread about something similar. Fuses seem to be fine. All other lights work fine, and it's not a dimmer switch/headlamp issue, which is what my searches seemed to find. Any suggestions?
lccl is offline   Reply With Quote
Old 01-20-2013, 02:35 PM   #2
Hangry
Member#: 342172
03 WRX Wagon
sedona red pearl
Any luck with this yet? I'm trying to find similar info..
Hangry is offline   Reply With Quote
Old 12-30-2014, 09:50 PM   #3
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
same issue here. any luck?
David Medina is offline   Reply With Quote
Old 03-02-2016, 08:20 PM   #4
Euronj
Member#: 380020
2004 Wrx
Have same sort of issue. Light behind engine temp is out
Euronj is offline   Reply With Quote
Old 03-03-2016, 02:21 PM   #5
LIChuck
Member#: 266122
2007 WRX Limited
UGM
Have you tried replacing the bulbs?
LIChuck is offline   Reply With Quote
Old 03-03-2016, 03:40 PM   #6
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
You are going to have to take the cluster out and start with the easiest thing... check your bulbs. After that, use a power probe or meter to ensure you are getting power. Then depending on what you find, you can narrow down the issue.
For the guys with one light out, it's likely a bulb. If it's like half the dash all of a sudden, it's obviously something else that's going to be a little more involved.
bdubblu is online now   Reply With Quote
