Old 12-11-2012, 05:28 PM   #1
kdoggparker
Member#: 320358
Default 04 STI coolant leak
This dos not suprise me but i have a coolant leak in my 04 sti.... its comeing from the pass side behinde the timeing case cover.... any thoughts on what it could be before i rip the car apart and how much im looking to spend prolly?
kdoggparker is offline   Reply With Quote
Old 12-11-2012, 06:25 PM   #2
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
You should have posted this under the 2.5L Power train section firstly. Secondly, Define behind the cover. Sandwiched between the front cover and back? Behind it completely? Only thing on the passenger side for coolant I can think of is the coolant crossover.
Old 12-12-2012, 11:45 PM   #3
al_s14
Member#: 168077
13 sti
PBP
oil cooler hoses leaking may look like a drip from behind the pass side timing cover if youre not familiar with the layout. or upper hose at engine will easily drip in that area and wont be visible from the top
other than that as Hinshaw said there is nothing there
al_s14 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 10:28 AM.
