#1 |
Member#: 337170
Vehicle:2003 wrx silver |
I was planning on fitting my engine with ARP studs and main bolts till I found out they would cost me $600 combined! that is insane for bolts! are there other routes I can take or should I stick at stock? I ordered Manley forged pistons and eagle H beam rods so it will handle abuse of 450+ whp but I plan to achieve only 350. ideas?
#2 |
Member#: 111048
Vehicle:I <3 debt word rally suck. |
why do you need main bolts?
#3 |
Member#: 337170
#4 |
Member#: 97135
NWIC
#5 |
Member#: 339830
International
Vehicle:2007 Forester |
better is pay for good parts for motor build than for refurbish engine..
#6 | |
Member#: 111048
no offense. add to the price of those bolts a nice line hone and that'll put ya well over a grand for just those 2 parts. |
#7 | |
Member#: 337170
#8 |
Member#: 230719
Vehicle:2005 Sti Andrewtech & TurboXS FTW |
Do it right the the first time.
I did ARP case bolts, head studs, and rod bolts |
#9 |
Member#: 337170
what was the total? I got my pricing from JSC. I'll have to bite my lip and pay up it looks like! I don't want to have problems later down the road especially since these motors can't be worked on while in the car
#10 |
Member#: 309599
Vehicle:2006 STi CGM |
Shoot me a PM with what you need and maybe I can help you out. A motor build is extensive and a large investment. Rule of thumb, be READY to pay the double amount of your budget if stuff requires attention/replacement right away. It can get costly quick.
#11 |
n00b Moderator
Moderator Member#: 140114
Vehicle:06 18G Semi Built SGM WRX |
At 350 whp you don't need ARP anything.
#12 |
Member#: 255776
Vehicle:2010 LR WRX MPS and PAR powered. |
I didn't get ARP case bolts for my motor, I stuck with stock for that, but I did go with ARP H11's for my studs.
#13 |
Member#: 337170
that's what I was thinking. it's getting a 20g turbo and a big tmic with EQL headers. besides that, I have invidia turbo back, aps 65mm intake pulling from the fender, and 1,000cc injectors. although arp would be a great piece of mind! I'll more than likely do it.
#14 |
Member#: 255776
Dom told me I didn't need ARP head studs, but I wanted the peace of mind as well. Just do them if you can afford it. It'll keep your mind at ease.
#15 |
Member#: 91347
NESIC
Vehicle:'13 XV Crosstrek, 1050 Triumph Speed Triple |
Do some research in the "Built Motor"
I think you'll find that your stock block is fine. Doesn't sound like you're changing any internals. |
#16 |
Member#: 300551
SCIC
Vehicle:2002 DD wgn 6 spd 2.1 kel 272's meth 2.5xtr |
#17 | |
Member#: 300551
SCIC
Add meth, stroker and it looks like my build. I just used arp head and rod bolts. We are along ways from needing block bolts. Last edited by mod maniac; 12-06-2012 at 07:17 PM. |
#18 |
Member#: 255776
Dom and I briefly spoke about them and he said that the regular ARP studs aren't much better (if at all) than the stock bolts. I don't think he would have let me spend money on the regular ARP studs
He's a good dude. Puts up with a metric **** ton of questions from me... |
#19 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
#20 | |
n00b Moderator
#21 |
Member#: 255776
I'm guessing 08+ WRX and he's worried about the stock tranny so he's going to keep it around 350.
#22 |
Member#: 337170
here's my story, slipped a rod bearing and limped home. luckily I was a mere 1/2 mile from home. it's my 03 wrx and I want to build it to be fast but still last 100,000-150,000 miles. trying to save the tranny so I'm gonna stick with the stock clutch. the plan is to put the H beam rods and forged pistons in, stock cams, oem gaskets, get the crank, flywheel, and pressure plate balanced, and BC valves. 3 months after I finish the motor I'll add the 20g turbo and gt spec equal length headers. an intake manifold MAY be in the list but not for sure. gonna stick with TMIC. I already have the invidia turbo back, 1,000cc injectors, and the APS 65mm cold air. it should be capable of 420+ but I'm hoping to maybe run low boost and sit around 350.
#23 |
Member#: 255776
Well, at 350whp with your tranny, I'd be worried. At 420whp...
good luck. |
#24 |
n00b Moderator
He can write a long post, but not fill out his profile.
![]() And you can upgrade your clutch while the motor is out. Plus the whole "glass transmission" argument is about as dumb as all the ringland arguments. |
#25 | |
Member#: 337170
edit: just used safari and went to the full site and updated everything! I<3 iPhone Last edited by rushdylan; 12-06-2012 at 06:10 PM. |
