#26 |
Member#: 91347
NESIC
Vehicle:'13 XV Crosstrek, 1050 Triumph Speed Triple |
#27 |
Member#: 130666
Vehicle:2006 WRX STI Black |
I put down 475whp and didnt use arp anything
oem headgaskets ftw! |
#28 |
Member#: 337170
Vehicle:2003 wrx silver |
#29 |
n00b Moderator
Moderator Member#: 140114
Vehicle:06 18G Semi Built SGM WRX |
#30 |
Member#: 100300
Vehicle:06 WRX CGM |
Don't expect you built motor last as long as a stock one. Forged pistons are not great for longevity. Apparently it is a common misconception that built motors will last as long/longer than a stock one.
#31 |
Member#: 337170
would that be because of the bore/hone not using a torque plate?
#32 | |
n00b Moderator
![]() On a serious note, they tend "not to last as long" because when the motor is cold, they have room to float around in the cylinder and give you piston slap. As the pistons warm up, they expand and fill the void. Of course this is all dependent on the quality of the engine builder. |
#33 | |
Member#: 98000
Vehicle:05 sti e85@420hp |
You may want to check into this but IIRC, forged pistons generally have less silicone than cast, higher silicone content can lessen wear. |
#34 | |
Member#: 300551
SCIC
Vehicle:2002 DD wgn 6 spd 2.1 kel 272's meth 2.5xtr |
I build my motor so I can pump it up to 400 or 500 whp and then wonder why it only lasts 70k. Who knows how long a built motor would last at 170 whp, not me and probably not anyone else who builds one. |
#35 |
Member#: 100300
True. I just thought I would throw what I said out there. Hopefully the OP's engine lasts a long time and is everything he hoped for.
#36 |
Member#: 332887
Vehicle:2012 WRX stage 2+ DGM (sedan) |
#37 |
Member#: 337170
ummmm yea. the motor in my dirtbike is a 4 valve 14:1 compression and revs to 13,500. after I ported it, popped in some good cams and ceramic bearings, it didn't last long. cylinders would go out of round pretty quickly and the cams ate valves for lunch! I once built a $2,000 head for it. I had it stage 2 ported and polished, titanium flat faced valves, titanium retainers, super stuff valve springs, copper alloy valve seats with 5 angle cut and copper guides as well, and it was resurfaced and everything. it cost a lot for a little 4 valve head but that thing lasted longer than any other head! my biggest problem with the car will be holding back from pumping tons of boost! but I think I'll be okay.
