Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 12-06-2012, 06:01 PM   #26
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
dude your car is under power train warranty, just drive it.
Old 12-06-2012, 06:22 PM   #27
lingling1337
Member#: 312120
^ And if there's some problem they refuse to fix... keep it in boost
lingling1337 is offline   Reply With Quote
Old 12-06-2012, 06:29 PM   #28
tibug
Member#: 273906
2003 Outback 2.5
1993 Dakota 3.9 4wd
Originally Posted by leecea View Post
Actually not.
Yea, I ran low on oil shortly after buying my car and the oil pressure light turned on when I went around corners. Added slightly more than a couple quarts ( ) and it runs fine to this day ~20,000 miles later. Was there damage done? I'm sure, but it hasn't manifested itself yet.
tibug is offline   Reply With Quote
Old 12-06-2012, 06:35 PM   #29
chulooz
Member#: 159438
99 GC8
I would not accept the car till I saw compression and leak down figures, once you take it its your problem again. And once you do take it drive it right away, hard... you almost want to try to replicate any issues that could be somehow covered up; work that motor in every gear. Dollars to doughnuts they left the old oil seal on there... oil seal failing, get the hell out.
chulooz is offline   Reply With Quote
Old 12-06-2012, 06:48 PM   #30
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
wow i've never ever heard of a failed oil filter seal....
murrdogg24 is offline   Reply With Quote
Old 12-06-2012, 06:58 PM   #31
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Originally Posted by KOJAK-02-WRX View Post
Subscribed to see how this turns out, local to you and was about to start using them instead of Neil Huffman since it is closer.
With a join date of 2009? Things that make you go Hmmmmmm...
G-Omaha is offline   Reply With Quote
Old 12-06-2012, 08:33 PM   #32
tibug
Member#: 273906
2003 Outback 2.5
1993 Dakota 3.9 4wd
Yea it kinda sounds like bullcrap to me. Maybe there was gasket residue on the block surface and they didn't clean it off? Who knows, but that sounds fishy.
Old 12-06-2012, 08:51 PM   #33
kenlee
Member#: 49341
I don't think a compression test is going to show bearing wear/failure. If the motor suffered detonation or something, sure. Any remaining oil that Subaru would have removed would have metal particles due to accelerated bearing wear. Good luck man.
kenlee is offline   Reply With Quote
Old 12-06-2012, 09:19 PM   #34
Freeagnt54
Member#: 339011
13 WRX Hatch
I would want a new motor, or at the very least a powertrain warranty increased to 100k
Freeagnt54 is offline   Reply With Quote
Old 12-06-2012, 09:30 PM   #35
db97
Member#: 7140
2009 WRX
satin white pearl
Actually not. Years ago I had the oil filter fall off after leaving a dealer who just changed my oil and put the wrong filter on (not a Subaru). I saw the red light, immediately stopped, and had the car towed. Car ran fine for the rest of the time I owned it. Maybe it had taken some life off the engine, but it certainly wasn't game over.
I've never heard of an insurance company covering this type of thing. They cover accidents, not breakdowns. Are you sure this is even an option?
yep...the insurance lady said it's got coverage for stuff like this...falls under misc damage.
db97 is offline   Reply With Quote
Old 12-06-2012, 09:31 PM   #36
SpamBot
Member#: 287534
Originally Posted by Steve.804 View Post
Paidfor are you a trained subaru tech?
No, but he did stay in a Holiday Inn Express.
OP, pick the car up, drive it. If there are compression and/or leakdown issues, you'll feel it in the engine. If so, then bring it back to the dealer to have things checked. Otherwise, keep your paperwork, and don't get your undies in a big knot.
SpamBot is offline   Reply With Quote
Old 12-06-2012, 10:17 PM   #37
cpt jack
Member#: 328696
Chapter/Region: HIIC
1992 Legacy SS
Maroon
Funny you say that, this guy i work with has an Si and hit a puddle and it gulped in a nice chunk of water..... 2 weeks later he has a new engine. I didn't know they cover that kind of thing but apparently they do!
cpt jack is offline   Reply With Quote
Old 12-06-2012, 10:24 PM   #38
db97
Member#: 7140
2009 WRX
satin white pearl
Default uhhh
for 11k more miles...then poof...gone!
i asked them what happens if the engine croaks at say 65k miles...guy simply said we would address it at that time???
i drove it home, and drove it hard...i kept smelling a burning smell...which probably is residue from the burning from yesterday...and the car no longer has that smooth rise of power like it use to...i can tell it's gotten rougher now...like more laborious if that makes sense. deep down inside, i wanna tell myself nothing is seriously wrong, but i know that isn't the case...you drive a car with no oil or very little oil...it then violently dies on you and makes a loud exploding like noise...something went very wrong. i just know my car will never be the same, and it's damaged goods. the whole oil filter seal failure is way to fishy as well...i asked them for the all paperwork their service mgr was supposedly submitting to SOA...when i got back to pick up the car...the service guy left...the service mgr left...and i rec'd a one page receipt...basically minimizing the status of what happened to my car. now i am really mad about this whole mess.
Old 12-06-2012, 10:29 PM   #39
rockyraccoon
Member#: 260965
2010 WRX
I would go back and trade it in. Especially since you said you only owe $6k. You have Subaru's guaranteed trade in program, which you can figure out on their website with vin and mileage.
rockyraccoon is offline   Reply With Quote
Old 12-06-2012, 11:22 PM   #40
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
Wow that sounds hella shady
Old 12-07-2012, 12:02 AM   #41
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Put sum Dales Seasoning on it.
nightcrawler60 is offline   Reply With Quote
Old 12-07-2012, 12:28 AM   #42
Smoochie
Member#: 104710
2007 WRX STi Ltd#695
Urban Silver Metallic
Man, I've never seen so many redundant question marks and exclamation marks...
DB, I think it's time you sat down with the manager of that facility. If it were me (and I was remotely considering a new car), I would run by an attorney's office and shake hands (grab a card) on this issue. Then, I would politely share the card with the Manager while discussing options. Options such as wholesale price on a WRX. I would explain your involvement in the Subaru community and make sure he understands that you would love to represent their dealership in the proper light with a new WRX.
In the case that he doesn't see you driving a WRX at a wholesale price, I would certainly pursue a new motor and I would start with a second service opinion documented with compression/leakdown tests. This isn't inexpensive as a process, but it IS something I would pursue.
Any Lawyers on here have an angle on this?
Smoochie is offline   Reply With Quote
Old 12-07-2012, 02:30 AM   #43
SoulAmazing
Member#: 318936
2003 Impreza
lmaooo
SoulAmazing is offline   Reply With Quote
Old 12-07-2012, 07:15 AM   #44
Knotsure
Member#: 41730
0910 Leggy3.0/Impr
BLU Leg/BLK Imp
Have you called Subaru and asked that they document the situation, get one of their techie types $.02, and to ask them to intercede with copies of the dealer docs., etc.? I've read on these very same boards how helpful they can be...
Knotsure is offline   Reply With Quote
Old 12-07-2012, 08:40 AM   #45
SpamBot
Member#: 287534
You're not going to get through to one of the "techie types" at SOA. You'll be talking to a customer service rep, who knows nothing about the inner workings of an engine.
SOA is not about to cut one of their dealers off at the knees over this issue. They will call the dealer, the dealer will tell them the issue has been rectified and the car is fine, and that will be the end of it.
Old 12-07-2012, 09:34 AM   #46
sorrowfulkiller
Member#: 170439
I <3 Lamp
Heres what i would do OP. Call SOA, make sure it is documented completely, exactly what happened down to the T, talk to them about getting the next oil change independently tested to test for bearing material, offer to send them some of the oil also. It would also be wise to take the car to a different dealership to get another opinion, let them know that the dealership that usually services your car will be the ones replacing the engine if it comes down to it so you know that it is not going to be a burden for them in the long run. Past that if it comes back that there is excessive bearing material then I believe you would then have the smoking gun and can ask SOA to foot the bill for a NEW engine.
Blackstone labs does testing and many users on nasioc have used them.
sorrowfulkiller is offline   Reply With Quote
Old 12-07-2012, 10:32 AM   #47
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^^^^^^^^Blackstone is the shizzert!!!!
Do it
Do it
Do it
Paidfor is offline   Reply With Quote
Old 12-07-2012, 10:39 AM   #48
oharao2
Member#: 229802
2008 WRX STI
they called me back...said my car is ready. said it runs "great" ??? of course they would say that. now the guy never did confirm the fail safe thing...he just said they are filing the paperwork to SOA as a defective filter...and they would refund my money and clean the bottom of the engine for free...how nice of them
i asked them...if my engine dies after 60k miles...then what? he said we would have to address it at that time...he also said understand about wear and tear?? i mean maybe it was a defective filter...OR maybe like what one of the posters said...maybe they forgot to remove the previous seal and it caused this to happen..!@#$
i feel like demanding a new engine but something tells me they won't do it...if i go to my insurance company and file a claim...they would pursue a new engine, but ultimately...the "new" engine would only be a used/junked engine from some junkyard (ky law doesn't require vehicles with destroyed engines to have to replace them with new engines...insurance lady told me that)
i'm headed back up to pick up my car...i am going to ask that they run these compresssion and leak tests to ensure the vehicle is properly working. i'm gonna need to talk to the service mgr about that.
in the end, i'm already feeling like i need to get a new car b/c my baby is now "scarred" ...ughhh. and i had 6000 left on the bank note !@#$!!!!!
for you posters in the know...what exactly do i ask them in terms of these tests? a cylinder compression test and a leak test? help me out fellas...appreciate all the feedback.
I would get SOA involved just so they know whats going on in case something does go wrong. None of that we'll approach that bridge when you get there (this is another way to say sorry but your screwed). I'd also get a SOA non-Bachman tech to take a look at the car just to make sure what the dealer is saying is correct and that the motor is fine. I would also get a 100K extended warranty out of them. This of course is if you cant get a new engine out of them. These engines should last for 200K (other pieces might not like the turbo) but i imagine this could cut this life seriously short..They should also tear down the motor and do a full inspection.
oharao2 is offline   Reply With Quote
Old 12-07-2012, 10:42 AM   #49
Knotsure
Member#: 41730
0910 Leggy3.0/Impr
BLU Leg/BLK Imp
That's what I'm saying. And while a tech. person won't be answering the phone, they have access to them. Also, once it is documented, it won't be a matter of SOA throwing the dealer under. It'll be a matter of doing what's right. Even if it means helping the OP get into a new car, or with an engine replacement once the warranty is up. Saying it was reported on Nasioc won't do diddly.
Old 12-07-2012, 11:33 AM   #50
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
Huh? Why are you questioning me? Because I posted to subscribe? Was getting his opinion on Neil Huffman if Bachman was in deed bad.
KOJAK-02-WRX is offline   Reply With Quote
