Old 12-06-2012, 11:23 AM   #1
betterthansx
Member#: 259103
07' Mazdaspeed3
Cosmic Blue
Default GOLD Foil Application Thread (Silver also acceptable)
I have been looking into using some reflective/insulated foils and have learned to love the look. It looks to be a good way to reduce IAT's as well as protect certain areas that may be prone to damage from heat. It may look cheesy but if it works, I am down, but you definitely have to use the better products to take advantage of their insulation/reflective traits.
I am curious who has used it and how it has worked, plus post pictures to show how and where you have used it.
McLaren F1
Evo
Evo
betterthansx is offline   Reply With Quote
Old 12-06-2012, 11:43 AM   #2
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
I used the silver to wrap all the sides of my old STI tmic and Y-pipe .
The turbo side seemed to stay much cooler to the touch after spirited driving.
No real numbers to back it up, but the hand warmth test showed some differences between wrapped and not.
No real pictures, use your imagination, just a really shiny tmic.
I also use the tape to keep the exhaust on my ATV from melting plastic parts, to keep heating lamps for critter cages from melting stuff, fix leaks in AC vents. I find it to be quite useful.
I can definitely say the heat reflective tape works in a lot of situations, hell I made a patch out of like 5 layers to cover a hole in a mid pipe, held for the better part of 6 months and was hell to get off in the end.
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 12-06-2012, 11:56 AM   #3
Ultimateone
Member#: 48025
15 Mustang GT
It works, it's been proven.
Ultimateone is offline   Reply With Quote
Old 12-06-2012, 12:40 PM   #4
betterthansx
Member#: 259103
07' Mazdaspeed3
Cosmic Blue
Check this out,
http://forums.vwvortex.com/showthrea...3#post79953803
Plus this. This guy seems to know what is the best stuff and where to use it.
http://forums.evolutionm.net/evo-eng...vs-silver.html (READ FIRST POST, THEN READ POST #29 ON PG.2)
http://earlsindy.com//home/store/pro...oducts_id=2735 (NOT SURE IF THIS IS WHAT HE IS TALKING ABOUT)
I would love to see someone do some data logs before and after.
Old 12-06-2012, 05:21 PM   #5
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
WRX8XB is offline   Reply With Quote
Old 12-06-2012, 05:56 PM   #6
Never gone
Member#: 338850
Never gone is offline   Reply With Quote
Old 12-06-2012, 10:15 PM   #7
betterthansx
Member#: 259103
07' Mazdaspeed3
Cosmic Blue
Originally Posted by Never gone View Post
That was actually really cool.
I did not expect it to more than half the temp!! Crazy, thanks for posting.
Old 12-07-2012, 12:19 AM   #8
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
I taped my firewall near the turbo as my ecu is really close there and it was cooking inside (firewall insulation mat gone)
found the pic:
alcoolaid is offline   Reply With Quote
