Old 12-06-2012, 12:04 PM   #1
LionJ5
Member#: 180596
Subaru Stars Phase 1 Phase 2 Questions
I am totally lost as I have done much searching but am now confused. I have a 98 OBS with 235,000. My questions are as follows:
1. Is this engine Phase 1 or Phase 2?
2. Is this engine OBDII?
3. I have chance to get a 2.2 from the junkyard thats been tested as good. They cannot tell me (or wont) what year this engine is. What 2.2's will "Drop-In" to the 98 OBS?
Thank-you in advance.
LionJ5 is offline   Reply With Quote
Old 12-06-2012, 01:00 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Phase I EJ22 interference engine, yes OBD-II. Pretty much any EJ22 between 1990-1998 will drop in, all you have to do is swap your intake manifold onto the "new" engine and call it a day. You might have to mess around with the EGR sys. if your new engine's heads don't have a bung for the EGR pipe. But you might be able to drill and tap that.
~Josh~
Old 12-06-2012, 01:29 PM   #3
LionJ5
Member#: 180596
Subaru Stars
thank you sir. That answered my questions.
Old 12-06-2012, 11:18 PM   #4
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
~Josh~
I thought his would be a phase II. Also not all Phase I EJ22's came with dual port headers and some are OBDI while others are OBDII. There is also the issue of EGR on some model years but not on others.
OP you can look at the vavle covers and see if they are flat and have the sparkplug entering through the valve cover. If so, it is Phase II. Same can be done to determine compatibility with the junkyard motor.
geronimo81 is offline   Reply With Quote
Old 12-07-2012, 12:36 AM   #5
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
1998 should be OBDII regardless, unless someone previously swapped in an OBDI motor.
Counterfit is offline   Reply With Quote
Old 12-07-2012, 12:40 AM   #6
StripesRX
Member#: 219762
2004 WRX STI/ 00 OBS
PSM / BRP
Unless the 2.2 came out of an early OBD1 Legacy, all other 2.2s have single port headers.
That being said, any 2.2 will bolt in with minimal fuss.
StripesRX is offline   Reply With Quote
Old 12-07-2012, 09:10 AM   #7
LionJ5
Member#: 180596
Subaru Stars
Thanks again for the responses. Im going to the junkyard today and now know what to look for.
