Old 12-06-2012, 02:50 PM   #1
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
Default what pads fit Rotora BBK, really..
I need some new pads again and that brings up the question, what pads other than Rotora really fits the fc4 calipers? Ive tried the HB193Z.670 Hawks mentioned before and they are to thick to fit in. Rotora sent me a drawing for specs but no recommendations from them. To the guys that have this brake kit, what have you ran that works 100%?
ddavisgt is offline   Reply With Quote
Old 12-06-2012, 11:39 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
you have to modify pads to make them fit, as far as i know...that is the only way
Old 12-07-2012, 12:15 AM   #3
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
That 17mm thick (0.670") shape is a very common Porshe/Brembo shape. Everyone makes it.
Rotora uses a thin version of it.
Any machine shop can mill/blanchard grind them down however.
Yet Hawk does make a pad that is thinner than the 18mm, the thickness they also make is 15mm
-Ken
KNS Brakes is offline   Reply With Quote
Old 12-07-2012, 10:30 AM   #4
ESmooth
Member#: 118082
You can get StopTech Street Performance pads that are already modified to work with your calipers here:
http://store.excelerateperformance.c.../i-395170.aspx
ESmooth is offline   Reply With Quote
Old 12-07-2012, 12:35 PM   #5
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
Do you know the thickness of those? Direct fit any pics of the pad?
Old 12-07-2012, 01:44 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
uuummmm....that d00000d works for stoptech...he should know
so direct fit....yeah
i guess they started makin the pads for guys like you...ya got lucky
Old 12-07-2012, 02:06 PM   #7
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
Awesome, thanks for the heads up!
Old 12-07-2012, 03:17 PM   #8
KNS Brakes
Member#: 125739
2015 WRB WRX
We have found that Hawk has a thinner pad, HB193.610 which is only 15mm thick instead of .670 (17mm).
Downside of that is the 15mm version is only available in DTC-70/60 compounds.
-Nick
Old 12-07-2012, 03:25 PM   #9
KNS Brakes
Member#: 125739
2015 WRB WRX
Here is the thickness of the stoptech pad, 17.3mm is even thicker than the Hawk .670 thickness.
-Nick
Old 12-07-2012, 03:52 PM   #10
WhatTurboLag?
Member#: 243992
2006 WRX TR
Aaaannnnndddd this is why rotora rotors suck -_____-
WhatTurboLag? is offline   Reply With Quote
Old 12-07-2012, 03:59 PM   #11
ESmooth
Member#: 118082
The pads are actually based off the D1001 pad shape...this was discussed in another thread previously but a quick search did not bring it up:
Old 12-07-2012, 04:34 PM   #12
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Originally Posted by WhatTurboLag? View Post
Aaaannnnndddd this is why rotora calipers suck -_____-
Fixed, I think.
Counterfit is offline   Reply With Quote
Old 12-07-2012, 05:23 PM   #13
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
They came on my car when I bought it, wouldnt have been my first choice for sure. Stoptech pads ordered
Old 12-08-2012, 10:46 AM   #14
liltoua
Member#: 206802
1998 2.5rs
Let me know if those work
liltoua is online now   Reply With Quote
Old 12-08-2012, 05:25 PM   #15
WhatTurboLag?
Member#: 243992
2006 WRX TR
Originally Posted by Counterfit View Post
Fixed, I think.
Yes lol I was half asleep when I said it
Old 12-10-2012, 11:00 AM   #16
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
Any of you guys have information on replacing rotors for their bbk kit? Their rotors are larger then the stock wrx rotors and are the 2piece style that came in the bbk kit. 330x30mm, $250 each through rotora.......;(
Old 12-10-2012, 11:31 AM   #17
Counterfit
Member#: 124254
"The Scoobinator"
I think most people have replaced the whole kit rather than deal with weird rotors and pads.
Old 05-17-2013, 10:02 AM   #18
imprezkid
Member#: 71462
2001 2.5rs
STM
^ You sure are a lot of help in this thread. ddavisgt did the pads work? I'm working to try to find other rotors that will fit the brakes. I think with the smaller pads you could fit a 330x32mm rotor, but i haven't confirmed yet.
imprezkid is offline   Reply With Quote
Old 05-17-2013, 10:12 AM   #19
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
The Stoptech pads worked great. I never looked more into rotors since I dont need them yet, but if you find some let me know. Would be good to know when the time comes.
Old 05-17-2013, 11:00 AM   #20
MyRuRex
Member#: 21349
02 WRX Wagon
I had rotoras, guessing same 4-pots..
Someone told me it's the same caliper as the '00 Viper, Jaguar XK-R and the Ferrari F-40!!
And yes, I believe some shaving of the pad is required...
MyRuRex is online now   Reply With Quote
Old 05-17-2013, 11:14 AM   #21
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
It's easy to use the same caliper for multiple applications. They just need to change the piston diameters and mounting location of the caliper to get the proper pressure and torque output. That said I wouldn't trust a Rotora caliper on a Subaru. I definitely wouldn't trust it on a Viper or an F-40. The stock brakes on those vehicles are likely superior.
Stoptech has their basic ST40 caliper in many, many applications, but the pistons, mounting brackets, and rotors are tuned for each application. It increases common parts making volume ordering cheaper. It also makes for less confusion during assembly. It also allows a common pad shape across a lot of applications. In the end it's just easier to utilize a common design wherever possible.
Scooby921 is offline   Reply With Quote
Old 05-17-2013, 11:58 AM   #22
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I think you're misinterpreting what MyRuRex said, because what he said wasn't accurate. Going back to ESmooth's comment that the Rotora pad is based on the FMSI D1001 pad shape, that is the same pad shape as older Vipers and the F40. That's what whoever it was that told MyRuRex really meant. (Of course, it's also the same pad shape as the STI, Evo, 1st gen CTS-V, 350/370Z, and a whole bunch of other not nearly as exotic cars that use that same family of Brembo caliper design.)
Patrick Olsen is online now   Reply With Quote
Old 08-28-2013, 11:38 PM   #23
qnzwrx02
Member#: 303872
black
So did anybody find rotors that fit the rotora 4/2 pot for the 1piece?
qnzwrx02 is offline   Reply With Quote
