Old 12-06-2012, 03:57 PM   #1
LionJ5
Member#: 180596
Subaru Stars Which 2.2 is this
Can anyone identify this 2.2 as far as year (maybe theres something that will stand out that differentiates the year? The junkyard wont tell me what car it is from or even read any numbers off of the engine, however its a very good price if I can find out what year it is. Any help is appreciated. Thanks
LionJ5 is offline   Reply With Quote
Old 12-06-2012, 11:29 PM   #2
Subikid90
Member#: 239233
1998 LGT
It is an EJ22E SOHC. From what year, the world may never know. IIRC this motor did not change much over the years. What are you looking to put it into?
Subikid90 is offline   Reply With Quote
Old 12-07-2012, 12:08 AM   #3
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
If it is an EJ22E from 90-94, there won't be any EGR valve on the driver's side rear of the intake manifold.
EGR was introduced on the EJ22Es with the second gen Legacy from 95+.
Jessekrs123 is offline   Reply With Quote
Old 12-07-2012, 12:09 AM   #4
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Are the valve covers flat with the spark plugs going through them (Phase II) or are the spark plugs entering the head at an angle and outside the valve cover (Phase I)? What car are you trying to match it up with?
geronimo81 is offline   Reply With Quote
Old 12-07-2012, 10:08 AM   #5
LionJ5
Member#: 180596
Subaru Stars
Thank-you for the responses. It would be potentially going into a 98 OBS. From what I understand, I need a 98 2.2. I was told the one with the exposed head studs? I wanna make the install easy as possible.
Old 12-07-2012, 06:32 PM   #6
monkeyposeur
Member#: 333468
1993 SS
2003 WRB WRX 205/22T
If the junkyard 2.2 doesn't have an egr you will have a cel that you can't get rid of.
monkeyposeur is offline   Reply With Quote
Old 12-07-2012, 08:22 PM   #7
Jessekrs123
Member#: 236927
1984 BRAT
whoops
Old 12-07-2012, 11:04 PM   #8
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
It's a phase 2 engine. You can tell by the valve covers and the intake manifold. It uses the same valve cover/intake mani gaskets as the SOHC 2.5, has single port heads, and adjustable valve lash.
cal_look_zero is offline   Reply With Quote
Old 12-09-2012, 01:35 PM   #9
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
If you look on the bellhousing of the block, you should see a vin stamped into it, form that vin number you can figure out what engine it is.
~Josh~
