Old 12-06-2012, 09:24 PM   #1
Subarupower100
Member#: 312392
2007 Wrx tr
Rally blue
Default 38mm or 44mm wastgate
Hey can ya guys help me to what wastgate to use if I'm going to tun a 62mm turbo
Subarupower100 is offline   Reply With Quote
Old 12-06-2012, 09:33 PM   #2
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Depends more on how much boost you plan to run. The lower you want to be able to turn the boost the bigger a gate you may need
cowboy_Rob is offline   Reply With Quote
Old 12-06-2012, 10:05 PM   #3
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Whatever you can afford. There's nothing to lose by going too big.
drewvdw is offline   Reply With Quote
Old 12-06-2012, 10:07 PM   #4
Subarupower100
Member#: 312392
2007 Wrx tr
Rally blue
I think the most ill be running is 25 psi
Old 12-06-2012, 10:08 PM   #5
Subarupower100
Member#: 312392
2007 Wrx tr
Rally blue
So if I get a 38mm ill be fine
Old 12-06-2012, 11:09 PM   #6
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
The most you'll be running means nothing to us. We need to know the LEAST you'll be running.
Old 12-06-2012, 11:35 PM   #7
DDScooby
Member#: 161876
02 Impreza WRX
MOST tuners want a EWG bare minimum at 1bar (14.7psi boost). The practice is; the least amount of boost you want, you will need a bigger opening 38mm,40mm, 44mm, 46mm...etc. To be safe, just get a 44mm EWG and a 1bar spring and RUN IT!
Not sure if I explained that right. lol
DDScooby is offline   Reply With Quote
Old 12-07-2012, 12:22 AM   #8
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
^^^Pretty much. I wish I had gotten a 44mm EWG instead of my 38mm.
Old 12-07-2012, 09:37 AM   #9
tja1618
Member#: 181995
2003 WRX
I've heard some reputable tuners on here say the same thing in person - it's hard to control boost at lower levels (~20PSI) using smaller 38mm wastegates. I plan on running a 3071r on low boost using a 44mm.
tja1618 is offline   Reply With Quote
Old 12-07-2012, 01:04 PM   #10
Subarupower100
Member#: 312392
2007 Wrx tr
Rally blue
Oh ok guys thanks for the help .... Ill just get the 44mm
Old 12-07-2012, 01:48 PM   #11
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
This isn't exactly true... larger wastegates have slightly more sluggish spool. I would always recommend people to use a wastegate size that is enough to prevent boost creep... but not something silly like a 50 or 60mm wastegate.
My 2 cents,
Jasper.
jkopinga is offline   Reply With Quote
Old 12-07-2012, 02:45 PM   #12
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
No, they don't. Think about it. Why would it? Because it's bigger and has the potential to flow more?
Think about it like this, a fire hydrant can still move as much (or little) water as a garden water spigot. Both can keep it at a slow drip rate. The fire hydrant may be more difficult to set, but it is very possible to do.
Old 12-07-2012, 02:50 PM   #13
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Agreed^
Spool up isn't affected at all as long as you set it up properly
Old 12-07-2012, 08:11 PM   #14
fobiawrx
Member#: 91074
04 sti
white
Big Turbo/Low Boost = Bigger Wastegate
Big Turbo/High Boost = Smaller Wastegate
Small Turbo/High Boost = Smaller Wastegate
Small Turbo/Low Boost = Bigger Wastegate
fobiawrx is offline   Reply With Quote
Old 12-08-2012, 12:38 AM   #15
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Rotated BW S200sx-56
So what is considered low boost out of curiousity?
DerekB707 is offline   Reply With Quote
Old 12-08-2012, 12:47 AM   #16
Bones702
Member#: 205115
06 Sti Dom4.0XTR
I run a Dom4.0 At 17 pounds with zero issue with my Tial 38 MVR. I haven't had any issues with higher boost around 25 either. I doubt it helps but just laying it out for some info.
Bones702 is offline   Reply With Quote
Old 12-08-2012, 12:53 AM   #17
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
You people don't ****ing UNDERSTAND!!! High boost will be EASIER with a SMALLER wastegate. You can run no wastegate and all and get a bajillion pounds of boost! The point of a wastegate is to REDUCE the boost pressure. Just as using a turbo capable of 50psi (running at say 24psi) is better than running a turbo capable of 24psi (running at 24psi). The more headroom you have, the better.
Old 12-08-2012, 01:20 PM   #18
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Smaller gate, higher boost, bigger gate,lower boost.
That's always been my understanding
sense of nature is offline   Reply With Quote
Old 12-08-2012, 03:13 PM   #19
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
haha finally some good info
I was reading the posts and shaking my head lol
NW2TONE is offline   Reply With Quote
Old 12-08-2012, 08:32 PM   #20
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
From my limited experience, no subaru ever needs more than a 38mm. You get finer resolution/control with a smaller gate too.
KillerBMotorsport is offline   Reply With Quote
Old 12-09-2012, 10:09 PM   #21
sense of nature
Member#: 112759
SexyRP
Good to know, I'm sure you have more experience than most too
Old 12-11-2012, 12:04 PM   #22
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
My brother couldn't run a 38mm with his 6235 it would over boost constantly. But I agree no stock location subaru needs anything more than a 38mm. Sounds better as well
I completely agree with what you said.
medamullet is offline   Reply With Quote
Old 12-11-2012, 12:09 PM   #23
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
here is your proof.
