Old 12-06-2012, 11:02 PM   #1
claythrow
Member#: 283663
2004 WRX
Default Fuel injector change….
I've seen the tutorials and ready to do it. It seems to be a bit of a pain is it easier to take off the Intake Manifold first. I have the gaskets to replace on the TGV I just don't want to do anything unnecessary. I may need to take the IM off anyway which is why I ask.
claythrow is offline   Reply With Quote
Old 12-06-2012, 11:31 PM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
this is the general(idiot) forum
you want the technical forums for technical questions
and YOU DO NOT WANT OR NEED TO TAKE THE ****ING MANIFOLD OFF TO CHANGE INJECTORS
Old 12-06-2012, 11:39 PM   #3
mod maniac
Member#: 300551
2002 DD wgn 6 spd
2.1 kel 272's meth 2.5xtr
I do it in less than an hour but I do alot of them. Scotty is right it,s unnecessary to take the im off but if it is already off it's much easier.
Old 12-07-2012, 12:17 AM   #4
sorrowfulkiller
Member#: 170439
I <3 Lamp
Unbolt the fuel rails and the side fuel rail bolts on the tgvs. Pull up, slide out the olds injectors, lube up new injector o rings, slide in new injectors, rebolt everything.
sorrowfulkiller is offline   Reply With Quote
Old 12-07-2012, 02:55 AM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
do NOT forget the bolts on the front of the tgv's and do NOT bend the fuel rails
this isnt really difficult...but i have seen the job s00000oooooo p00ch screwed that i was just astounded
________________________________________________
and removing the manifold really does NOTHING for you as far as removing the injectors...it is a pointless waste of time and unnecessary complication that yeilds many fail points on disassembly and reassembly
Message Board Statistics All times are GMT -4. The time now is 11:05 AM.
