Old 09-13-2002, 03:11 AM   #1
WRX Power
Member#: 7142
Default Sedan rear strut top torque specs (for rear strut bar install)
Ok I did my searching and I came up with 14.5 ft/lbs. Just verifying if this is correct...
Also, is there a specific torque spec on the actual two bolts that connect the towers to the actual bar? Or is it just, "nice and tight?" (the bolt in this pic http://www.oakos.com/wrx/installs/RSTB/IMG_3495.jpg , even though it is a whiteline bar).
(This is for a Cusco rear strut bar install)
Thanks.
Bryan
WRX Power is offline   Reply With Quote
Old 09-13-2002, 05:22 AM   #2
M3sum
Member#: 18226
2001 M3
Laguna Seca Blue
yes its 14.5
im not sure about the strut tower bar though
M3sum is offline   Reply With Quote
Old 09-13-2002, 08:32 AM   #3
Austin
Member#: 7089
2016 STi
Default Re: Sedan rear strut top torque specs (for rear strut bar install)
You're not going to overtorque that bolt on a cusco bar with an allen wrench and your hand... so, yeah, just good-n-tight.
Austin is offline   Reply With Quote
Old 09-13-2002, 10:41 AM   #4
WRX Power
Member#: 7142
Thanks guys.
Bryan
Old 09-13-2002, 10:45 AM   #5
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
BTW, you're supposed to replace those nuts every time you undo them if I'm not mistaken, and I've read at least once where not replacing them has caused problems. I wish I had the link handy, but I don't.
And no, I didn't replace mine when I swapped my struts out, but... just so you know.
jblaine is offline   Reply With Quote
Old 09-13-2002, 10:52 AM   #6
ives
Member#: 7306
Hey Bryan,
Did you just get a strut bar or did you get other mods on the suspension? Just curious on whether you bought the RA's.
Tyler
ives is offline   Reply With Quote
Old 09-13-2002, 12:25 PM   #7
WRX Power
Member#: 7142
Originally posted by ives
Hey Bryan,
Tyler
Hey Tyler, long time no see...
I decided to get a stage 0 first, then throw on the coilovers. I still have it sitting around my house, just haven't had time to go up to Scooby Specialties and have them install it (along with my EGT probe). I kind of also want rims at the same time, but I haven't had the urge to dump 4K on the stuff just yet
Been out at all lately?
Old 09-13-2002, 12:27 PM   #8
WRX Power
Member#: 7142
Yes I read that somewhere.... anyone have the part # handy or should I be fine? I know at least 2 or 3 people that didn't replace them and they haven't had any problems.
Old 09-13-2002, 02:57 PM   #9
ives
Member#: 7306
I am going to need a ride after the stage 0 install.
I have been meaning to stop by Marina Blvd, but after the MTV thing on San Diego, I haven't been wanting to go. I've been curious if you have done anything to your car. I am still the same, but have big plans on my mind. Hope to see you soon.
Tyler
Torque spec for Ver5 strut bottom insert bolt Rallly2000 Brakes, Steering & Suspension 10 03-15-2010 12:59 AM
What is Torque Spec for rear diff mounting bolts? shemoves Transmission (AT/MT) & Driveline 2 11-07-2007 08:40 PM
torque spec for rear differential bushing bolt alltractionWRX Brakes, Steering & Suspension 1 03-08-2003 09:43 AM
Torque specs for rear swaybar mounts? Dave99 Brakes, Steering & Suspension 2 08-03-2002 05:37 PM
urgent: need torque specs for rear sway bar.... FormerSubTech Brakes, Steering & Suspension 1 01-26-2002 12:30 AM
