Old 12-07-2012, 08:59 AM   #1
1RareBreed
Member#: 338706
2004 RBB Flat 4
Default Crank pulley blew up.... WTF
Started my car this morning and half of my crank pulley blew off and smashed into the hood then the ground. I was like WTF! Turned the car off to take a look.
Would any internal damage happen on my 04 RS?? Kind of stuck in the driveway now with no effin car. FML
1RareBreed is offline   Reply With Quote
Old 12-07-2012, 12:04 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
I doubt that any internal damage was done, is the crank bolt still in place? Have any pictures? Check the radiator for any damage from flying pieces.
I'd say to inspect the belts also, if there's anything questionable, replace them. Think of this as a good opportunity to upgrade.
You can run the engine on battery power for a few miles if you absolutely need to, but unless you have a way to recharge the battery, don't simply leave it drained.
Old 12-07-2012, 03:24 PM   #3
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
I'd say just replace the belts anyway.
Counterfit is offline   Reply With Quote
Old 12-07-2012, 03:59 PM   #4
jthatch12
Member#: 321715
03 WRX
Seems legit
jthatch12 is online now   Reply With Quote
Old 12-10-2012, 01:50 PM   #5
vincent-h
Member#: 59504
2005 Impreza RS
pics?
vincent-h is offline   Reply With Quote
Old 12-10-2012, 03:37 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I'm guessing the outer part of the pulley separated from the rubber ring. That happened on my brother's old Eclipse (although his didn't fling up into the bottom of the hood!).
Did it do any damage to the hood, or did you just hear it and wonder WTF just happened?
Patrick Olsen is online now   Reply With Quote
Old 12-10-2012, 06:15 PM   #7
GrimmSpeed
Member#: 136396
2012 wrx
white
Yeah unfortunately it's some what common issue for Subaru's. We've noticed this on a bunch of different model/years.
Mike
GrimmSpeed is offline   Reply With Quote
Old 12-10-2012, 06:56 PM   #8
Counterfit
Member#: 124254
"The Scoobinator"
So this is just another reason to use a lightweight crank pulley.
Old 12-11-2012, 10:13 AM   #9
ImprezaSPEEDINNN
Member#: 259983
2011 2.5i Hatch OBP
e36 drifter ;)
that sucks.. i have a stock pulley ill sell you for real cheap if you need it.
ImprezaSPEEDINNN is offline   Reply With Quote
Old 12-11-2012, 02:08 PM   #10
1RareBreed
Member#: 338706
2004 RBB Flat 4
Yeah a small dent on the cross support bar on the hood thankfully, scared the crap out of me at 5am. got a agency power LW for dirt cheap new from a local company. Really wanted a grimmspeed lw but not luck and needed my DD Subi back on the road. like so.
Old 12-11-2012, 03:03 PM   #11
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
That's kinda funny - I had to replace a crank pulley on an eclipse a couple years ago... same issue.
axelthrasher is offline   Reply With Quote
Old 12-12-2012, 07:12 PM   #12
LeadFootedRacer
Member#: 340448
love the "thumbs up" for the busted pulley. never myself, seen that before
LeadFootedRacer is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 09:23 AM.
