![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 290129
Vehicle:2006 STi |
what are some decent control arms for a 2006 sti? i need some new ones.
#2 |
Member#: 254851
Vehicle:2002 Wrx wagon 5mt PSM |
Your car comes with what most people consider the best control arms. The 05-06 STI arms are it.
You are talking about control arms (front) and not lateral links (rear) right? |
#3 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
and why do you need new ones???
#4 |
Member#: 290129
Vehicle:2006 STi |
yes laterals, well I bought the car from a dealer and I took it to a mechanic(after buying) and the guy said they were so loose they stripped, he could tighten them with his fingers. the dealer said they don't see anything because they don't want to fix it I'm guessing. they said they are just bent, and they aren't the stock ones they are Perrin
#5 |
Member#: 1026
Vehicle:'00 RS/WRX Stg5 '98 RS Stock |
If your talking lateral links, unless there was a reason for the perrin ones, stock would suffice and you can get them all day in the classifieds...
#6 |
Member#: 254851
I agree with Aaron. Unless you need some adjustment in the back, you best route is to go stock (used is great and cheap) and just replace the bushings on them before installing.
Stock lateral links with some fresh bushings are hard to beat. |
#7 |
Member#: 254851
Once you replace the Perrin units and have them out of the car, you can see if they are repairable.
The dealer was probably not too keen on doing anything on aftermarket parts. Last edited by Bikelok; 12-08-2012 at 12:02 PM. |
#8 |
Member#: 131379
Vehicle:2003 354 ftlb@3k rpm justablue hatch |
googled perrin lat links and they're spherical bush one end, and adjustable. nice bits. I have whiteline lat links and the nuts/threaded arms are very robust.
suggest you determine exactly what the problem is. Start by learning how the arm works. + ask the mechanic to explain what the problems are, + you might ask to see the problem + Or jack the car up (use jackstands) and take a look yourself. Last edited by mhoerath; 12-09-2012 at 08:30 AM. |
