Old 09-13-2002, 09:39 AM   #1
Bill_WRX
Member#: 16502
Default Loud turbo whine / noice at idle
Just today I noticed a louder then usual turbo whine even at idle. I have a boost guage, it makes the noise when the turbo isn't even under load.
I'm real worried their could be something serious wrong.
I have a K&N filter and a Cat back exhaust.
Any ideas what it could be?
It did just get much colder around here. (I don't know if that has anything to do with it)
Thanks
Bill_WRX is offline   Reply With Quote
Old 09-13-2002, 09:48 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The turbo won't whine at idle, it's barely spinning.
You may be hearing some normal noise from the engine accessories and drive belt, I've noticed this when starting the car in colder weather. If it's this it should go away once the engine warms up.
If your K&N is a drop-in panel filter make sure the airbox is fully closed. You may have missed the two tabs at the bottom rear when you installed it (very common) and this can cause some noise as well.
Old 09-13-2002, 09:55 AM   #3
Bill_WRX
Member#: 16502
Thanks
I've had my K&N for over a year now, maybe it came loose (i'll check).
I'll see if the sound goes away after the car warms up, it really does sound just like a really loud turbo whine. It doesn't make much sense though if the car isn't under load.
anyone else notice this?
Old 09-13-2002, 10:21 AM   #4
HoleShot
Member#: 24524
it is very hard to tell with out hearing or seeing but a few things to inspect. Remove the intake and give the wheel a wiggle. you should have some play but not be able to make the fins contact with the turbine. DO NOT load the shaft and spin it as this will only damage it. JUst want to see is it moving back tot he point that it will make contact apon surge. A sound like a siren is a bad sign. this is the wheel hitting the housing and a sound that is of not the norm is not a good one. ONe thing that we are going to see a lot of in the WRX is turbo failer. With the factory unit being a TDO4 family turbo the bearing are just to the duty limit stock and higher RPM operation will only make life short. SO any added boost and a shorter then normal life span is expected. This is very much in the same as the 2G DSM where a T 25 is used to make 210 HP. ( BHP that is ) A car will make about another 40 till the unit just explodes. It's a case that the turbo will not hurt the motor unless something stupit is done to it.... And turbo's cost less then motors
Hope this helps.
BM-
HoleShot is offline   Reply With Quote
Old 09-13-2002, 10:41 AM   #5
Bill_WRX
Member#: 16502
I haven't increased the boost at all, although the exhaust should releave some back pressure.
It does sound like a siren, my girlfriend thought the police where around.
Is it bad enough where I should conisder having it towed?
Old 09-13-2002, 10:59 AM   #6
HoleShot
Member#: 24524
all depends on your location. I would look to some local WRX owners in your area and see what thay have to say "who is best" but remeber some views are slanted. Make sure you feel good with the shop and always ask questions.
Best of luck
BM-
Old 09-13-2002, 11:06 AM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Remember he is hearing this at idle so it is highly unlikely to be turbo-related.
I would lean more towards something accessory or belt related.
If you make a "stethoscope" from a piece of hose and probe around the engine compartment you may be able to localize where it is coming from and track it down. You can also take a long thin rod or screwdriver and place one end on different areas of the engine and hold your ear by the other end (just watch out for the hot things and spinning bits ). If you do this when the engine is cold it will be easier to work in there.
Old 09-13-2002, 03:03 PM   #8
Bill_WRX
Member#: 16502
I had my friend press the gas while I stuck my head over the turbo.
The sound does not appear to be coming from the turbo, it seems centered over the intercooler. I can obviously test this when the car is in neutral.
any ideas?
Old 09-13-2002, 06:32 PM   #9
suprasingle
Member#: 21733
1998 supra
wht
i have a vf22 (new)and i can hear it at idle very good,but not until i changed exhaust(silencer),and you prolly wouldnt hear it directly from above the turbo,more like air intake
randy,
if its a scock turbo i dont know if you can hear them very much
suprasingle is offline   Reply With Quote
high pitched whine at idle theostubbs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-01-2012 04:50 PM
jumpstarted car and now whine at idle p01ntb1ank Newbies & FAQs 4 08-04-2009 08:55 PM
Loud turbo whine cause found. Pictures and video. powerlabs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-04-2005 03:28 PM
High pitched hum/whine at idle... Brian Broz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-31-2003 10:30 PM
how do i get really loud turbo whine? STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-16-2001 11:28 AM
