Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 12-09-2012, 08:17 PM   #1
eric richardson
Member#: 338241
Default Blown motor, time for a rebuild!
Well three weeks ago I bought this 2007 STI with 73,000 miles. all stock, its been a blast to drive, handles amazingly etc.
Last week I bought a cobb ap and a catback exhaust, flashed cobbs 93 stage 1 tune. All was well for the first two days then all of a suddin on the way to work on the 3rd day I get a CEL for cyl 4 misfire, GREAT!! I had the feeling it was the worst, (cracked piston) so i checked the oil fill cap to find this;
http://i860.photobucket.com/albums/a...87F04E8767.mp4
the car still ran great it just had the cel, so i babyed it to work and back on the forth day, still good, a little puff of exhaust smoke at start up.
on the 5th day in the morning when i started it i get this!!!!
Im dumbfounded as to what made this happen or exactly whats wrong bud id guess its the piston?
ill be tearing into it later this week to see what happened...
next question:
Im wanting to do a forged bottom end, basically just pistons and rods and a freash rebuild. I was looking at buying an assemebled short block but not exactly where i should buy from? Ive concidered MAP Performance, or Element Tuning, but id like to here what places have great reviews for short blocks?
eric richardson is offline   Reply With Quote
Old 12-09-2012, 08:56 PM   #2
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Let me get this straight...You kept on driving it AFTER you figured out that a ringland was shot...
Call Dom at Maxwell Power Services.
drewvdw is offline   Reply With Quote
Old 12-09-2012, 09:07 PM   #3
Dillinja666
Member#: 332644
07 STI
It's white
Put a strobe light and a sound system in your garage and you're set! Sorry for you loss...
Dillinja666 is offline   Reply With Quote
Old 12-09-2012, 09:27 PM   #4
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Turbo may have blown up, its common! Stop letting it run unless you absolutely have to, but dont drive more than a few yards.
What likely happened here is;
Car was stock and drivin lightly, you got it as stated.... then modded it. Guessing you ran it up pretty high as any of us would do. This likely dislodged some oil oil debris or build up. It got caught in the OCV Screen before the turbo! This clogged the very very fine mesh screen and starved the turbo of oil. The turbine shaft seized & broke, and thus some oil is blowing right out the turbo housing and into the exhaust.
First, pull the down pipe off. Check for shaft pay or look in the turbo from under the car and see if the turbine is totally F*ed and just rattling around. If it is, pull the turbo get a new one and remove the OCV screen on the passenger side! Also remove the oil pan and clean it/check for debris. Many times when the turbos blow in this manor some of the journal bearing will go down the oil return tune and get down in the pan. Some can be small enough to get into the oil system and destroy bearings and cam journals. You can take the pan off with the engine in the car quite easily.
UK-Wagon is offline   Reply With Quote
Old 12-09-2012, 09:29 PM   #5
eric richardson
Member#: 338241
My last car was a champ, Turbo Lexus IS300, made 420whp on a stock 155k org motor. then this car blows with just exhaust and a mild stage 1 reflash? garbage, I should of done more reaserch before buying one of these.
i wasent for certian but guessing it was the piston from all the threads about this, stuff happens, Time for a built motor and a pro tune, im in too deep to back out now.
Old 12-09-2012, 09:33 PM   #6
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
No way that's the turbo u have exhaust gas going past the rings & into the crankcase.. hence, smoke outta the oil filler.
sense of nature is offline   Reply With Quote
Old 12-09-2012, 09:36 PM   #7
5050
Member#: 252122
2007 Sti
OPB
This! Just happened to a friends wrx. Same run down.
5050 is offline   Reply With Quote
Old 12-09-2012, 09:42 PM   #8
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
If there is smoke coming out the oil fill, then yes its mush worse. OP fix the link, it just goes to the pic of your smoking exhaust.
Old 12-09-2012, 09:43 PM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
So you had a complete inspection to include compression and leak down tests, right?
Old 12-09-2012, 09:52 PM   #10
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Don't blame Subaru, blame yourself or the previous owner(s).
Old 12-10-2012, 07:28 AM   #11
eric richardson
Member#: 338241
The car is parked now and ill be doing some testing later this week after work. Well see how that goes, till then ill be pricing out rebuild options.
Old 12-10-2012, 12:57 PM   #12
Decipher
Member#: 262760
2011 WRX Hatch Limtd
Satin White Pearl
I genuinely hope you have some money saved up. This is going to be expensive. Sorry man. I hate reading this. You obviously researched the cars so you knew about potential issues. You also should have read that a compression and leak-down test are a small but very necessary expense. Good luck.
Decipher is offline   Reply With Quote
Old 12-10-2012, 02:16 PM   #13
eric richardson
Member#: 338241
So I've been pricing parts, so far here is what I have came up with:
New sti short block - $1816.57
New sti gasket set - $266.66
New sti timing kit. - $127.46
New sti water pump- $124.06
New CP forged pistons $621.81
Head cleaning/ valve job- $170 per head.
Old 12-10-2012, 02:39 PM   #14
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Oil
TOB
Motor and tranny mounts (?)
Oil pickup tube (Killer B)
Clutch (?)
Flywheel/resurfacing
I'd also try to get that shortblock honed using a torque plate before dropping in the pistons.
Old 12-10-2012, 03:08 PM   #15
04ScoobyWtf
Member#: 287974
Did you buy the car from a private seller or a dealer because I would go legal on someone's @$$
04ScoobyWtf is offline   Reply With Quote
Old 12-10-2012, 03:58 PM   #16
Shortpersonbk
Member#: 319017
12 sti
broke and broken
LOL unless the dealer/prev owner screwed the car and then gave it to him you can't do anything legal.
He modified the car took the gamble and lost welcome to life.
On top of the modifications he drove the car for a couple WEEKS before anything went wrong.
Good luck with the fix, hope you have another car you could use as a DD while waiting. Are you just going to rebuild for stock or go big ?
Shortpersonbk is offline   Reply With Quote
Old 12-10-2012, 04:45 PM   #17
Decipher
Member#: 262760
Satin White Pearl
Exactly. Gotta love the general lack of accountability by some people. I bet he takes his car back to stock before going to the dealer, too. Own up, 04scoobywtf. Stuff happens and sometimes it's actually YOUR fault.
Old 12-10-2012, 06:32 PM   #18
eric richardson
Member#: 338241
I bought the car from a privet seller, the cars been great till I modded it, therefore it's my fault, things happen. The listed items above would be a good idea also.
All I'm doing is the forged pistons, and a new clutch. Nothing more I'd love to go all out on this one but it's cought me off gaurd and I don't have the funds to go too crazy.
Old 12-10-2012, 06:37 PM   #19
eric richardson
Member#: 338241
What is a "TOB"??
Old 12-10-2012, 06:39 PM   #20
207STi
Member#: 197062
1998 Swapped Impreza
black
Originally Posted by eric richardson View Post
What is a "TOB"??
guessing throw-out bearing.
207STi is online now   Reply With Quote
Old 12-10-2012, 06:40 PM   #21
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Throwout bearing. They're notorious for going bad, but if you're getting a new clutch, it'll probably come in the kit.
You really do need to look into the Killer B oil pickup. You don't want to kill your engine again.
Old 12-11-2012, 04:13 AM   #22
Spec R
Member#: 187752
99 RS/X5/Volt
ouch sorry to see this happen.
i too came into the subaru world expecting some a similar level of durability from previously owned cars, but have realized otherwise.
best of luck!
Spec R is offline   Reply With Quote
Old 12-11-2012, 06:40 AM   #23
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
Here are some options for preassembled shortblocks with forged pistons instead of buying a new OEM shortblock and putting your own forged pistons in -
Rallispec - $3500 (includes Cosworth pistons and Manley rods)
AWD Tuning - $2900 (from IIR, includes Arias pistons and ACL bearings)
You could also send your shortblock to CNC Engine Dynamics and they'll rebuild it with CP pistons for $2285.
FCmaniac is offline   Reply With Quote
Old 12-14-2012, 09:04 PM   #24
eric richardson
Member#: 338241
Tonight I did a compression test, I let the car warm up first. I was suprised to see that there was very little to No smoke coming out of the exhaust, it still has quite a good volume of air coming out of the oil cap.
I let the motor turn over 5-10 times per test and I used a Matco tools compression test gauge.
So here are the results
Cylinder 1 95psi
Cylinder 2 100psi
Cylinder 3 105psi
Cylinder 4 85psi
Old 12-14-2012, 11:05 PM   #25
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Yup, new motor time.
