Old 12-09-2012, 10:30 PM   #1
sburck
Member#: 191491
2011 Forester
Default Boring a subaru motor with an old school boring bar?
Well I have the feeling that this might be a terrible idea, but as a DIY enthusiast I thought it must be worth asking. Would using an old fashioned boring bar like the van norman 777 shown in the video below to bore out an ej block work, and work well?
sburck is offline   Reply With Quote
Old 12-11-2012, 10:54 PM   #2
sburck
Member#: 191491
2011 Forester
no ideas on this?
Old 12-12-2012, 11:50 AM   #3
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
It would work but you would need to mount the block on something more rigid than an engine stand. Also you would need to ensure the deck is prefectly flat as well as the bottom of the boring bar to ensure it is perfectly perpendicular to the bore. Modern boring bars will let you level the deck (on the fixture) as the boring bar is perfectly perpendicular to the fixture.
Crystal_Imprezav is offline   Reply With Quote
Old 12-12-2012, 07:43 PM   #4
sburck
Member#: 191491
2011 Forester
Would you need a torque plate?
Old 12-12-2012, 07:59 PM   #5
djdalaney
Member#: 301136
Nevermind.
djdalaney is offline   Reply With Quote
Old 12-12-2012, 08:08 PM   #6
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Stock head bolts or ARP?
theotherguy is offline   Reply With Quote
Old 12-12-2012, 08:26 PM   #7
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Originally Posted by djdalaney View Post
The head bolts aren't directly next to the cylinders, so torquing them down shouldn't cause any cylinder distortion. You shouldn't need a torque plate in this application.
What?
drewvdw is offline   Reply With Quote
Old 12-12-2012, 09:18 PM   #8
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
^ya I dont get that? Why wouldn't you need a tq plate?
Old 12-12-2012, 09:45 PM   #9
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
You do realize that torque plates are highly recommended with our engines, right? There has been measured and proven cylinder distortion when torquing head bolts/studs down.
Old 12-13-2012, 12:13 AM   #10
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
not when you bore, only when you hone.
Flat 4 Motorsport is offline   Reply With Quote
Old 12-13-2012, 12:31 AM   #11
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
^^^I guess I should've read into that a little, he may have meant it that way...
Old 12-13-2012, 04:30 PM   #12
djdalaney
Member#: 301136
Torque plates are only necessary if the cylinder distorts when the head is torqued down. The head bolts on the EJ engines are out at the edges of the block, so how does that cause cylinder distortion? I'm not familiar with EJ blocks, just general machining. I'm not saying you're wrong, I just don't see how torquing heads down is going to distort the cylinder that isn't directly connected to the head bolt holes due to the open deck design. Do you have any links to info on this?
See below.
Old 12-13-2012, 04:53 PM   #13
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
http://forums.nasioc.com/forums/show....php?t=1213861
This is just one that's in the "Links to great threads" sticky up top.
Old 12-13-2012, 05:29 PM   #14
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
In addition to the link posted, years of trial and error from Subaru engine builders, and torque plate use as a common practices in any QUALITY machine shop...ARP also recommends their use. According to their testing heat bolts/studs distort the cylinder in a localized manner in the area of the bolt/stud.
aboothman is offline   Reply With Quote
Old 12-13-2012, 05:31 PM   #15
djdalaney
Member#: 301136
That's what I'm saying. There are plenty of applications where a torque plate is completely unnecessary. Apparently the EJ is not one of those though. Actually, my engine rebuilding/machining teacher basically said, if they make a torque plate for a specific engine, it is probably needed.
Thanks for the link drew.
Old 12-13-2012, 05:32 PM   #16
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Search my SN for threads started. I did a whole test on TQ plates.
Old 12-13-2012, 05:34 PM   #17
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
^^^Yours was the one I really wanted to link him to. I just found that one faster.
Old 12-13-2012, 05:56 PM   #18
djdalaney
Member#: 301136
Wow, that does distort pretty badly. Thanks for that. All of your threads seem like really good info. Although, you still don't need a torque plate for boring, as the honing will be done after boring.
