Old 09-13-2002, 11:45 AM   #1
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
Default Anyone with Borla header and CEL, did the ECU recall fix the CEL?
When I asked my service writer about what the ECU recall did I was told that they essentially adjusted the range that the ECU accepted from the O2 sensor. Basically this was supposed to make the ECU less picky about the O2 sensor and make it less likely to throw a CAT inefficiency CEL.
I wondering if anyone who has a borla and has been getting the CEL has had this problem solved with the ECU reflash?
Suba_Roo is online now   Reply With Quote
Old 09-13-2002, 03:52 PM   #2
tcs007
Member#: 4103
2016 Mazda6
Red
I've got the Brullen headers, and it did make a difference.
The CEL comes on much faster now after a reset.
Probably not the answer you were looking for.
tcs007 is offline   Reply With Quote
Old 09-14-2002, 12:54 AM   #3
ScoobyRSRallier
Member#: 9686
00RS 05 lgt
Silverthorn, Silver
I did do the ecu recall, and after time the computer did adjust to the headers, but however during the winter months when it is colder out i still get that CEL.
-Ben
ScoobyRSRallier is offline   Reply With Quote
Old 09-14-2002, 01:37 AM   #4
ImprezedRS
Member#: 2771
2003 BMW Z4
ECU recall, when did this happen and what model years was it for?
ImprezedRS is offline   Reply With Quote
Old 09-14-2002, 11:40 PM   #5
Bob O
Member#: 1502
2000 2.5RS & SV1kS
BRP
Header wrap is your friend and usually will keep the "cat efficiency" CEL at bay. Wrap that rascal! Plus by keeping more heat in the exhaust stream this keeps exhaust velocity up, and you make more power! Not that you'd notice it, but it's something nice to think about when the incessant itching from handling the wrap (from the fiberglass in the wrap) makes you want to cut the offending apendage off.
Bob
Bob O is offline   Reply With Quote
Old 09-15-2002, 05:35 PM   #6
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
I have the Borla Headers and did the ECU recall fix. while the car drives much smoother now (bye bye hesitation) it still gets the CE light. BUT i don't think it may be a "Cat efficiency" code as more of a Cooler exaust temp CE light. Nothing to worry about, but header wrap will probably work.
anyone know if the Wrap will effect the warranty of the Header?
trojan9x is offline   Reply With Quote
Old 01-22-2003, 07:06 PM   #7
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
ok. I know.
Mr. ****
I would not wrap the header because then you will void the warranty. What
you can do is check for leaks and make sure the bolts are torqued correctly.
Then you can disconnect the negative side of the battery for a 1/2 hr to and
hr to reset the computer. If you have anymore questions please feel free to
contact me either by e-mail or by phone (877)462-6752 ext.212.
Thanks,
Richard A
Borla Performance
So... I'm not wrapping mine.
CosmoTheCat is offline   Reply With Quote
Old 01-22-2003, 07:31 PM   #8
jeffg
Member#: 2958
2001 6.0?RS
That same guy told me to wrap my header. What is the date on that email?
During the ordeal of getting my header replaced due to cracking, I spent a lot of time with richard on the phone. In the end they ended up including a 50ft roll of 1 inch header wrap in the box with my header. He told me that domestic guys have been wrapping headers for a long time and stainless steel wont rust.
I wrapped my header and you better believe I will make them warrenty them.
J
PS it got rid of my CEL also. even in the winter.
jeffg is offline   Reply With Quote
Old 01-22-2003, 07:38 PM   #9
CosmoTheCat
Member#: 3409
98 My FMIC
Today.
hmm.
I'd like to get rid of the CEL.
You'd think it would take a little while for the CEL to come on.. but it was instant. I'm wondering if I didn't screw up an O2 sensor. Gotta get that code pulled.
Old 01-23-2003, 08:20 AM   #10
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I have a buddy who had the borla gen 3 headers I think. He had wrapped his, and got cracks. He got a new set, and was told not to wrap them, and that was the cause of the cracking.
Whether that be true or not....I don't know.....but I probably wouldn't wrap them.
Legacy777 is offline   Reply With Quote
Old 01-23-2003, 04:04 PM   #11
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Lightbulb Options
ILP Check Engine Light Fix
ILP Performance has a solution BUT it may not be what you are looking for if you want the actual reason your check engine light is on fixed. It's an alternative though. I hate CE lights too.
Kevin Thomas is offline   Reply With Quote
Old 01-23-2003, 04:39 PM   #12
RSmatt
Member#: 8039
94 v2 STi RA - RHD
I had the ecu reflash done, and it did nothing to stop CEL's.
In august, I put on a cobb hi-flo cat. Since then I haven't had any CEL's. At first I thought that the light had just burned out. But when I go to start the car it lights up.
RSmatt is offline   Reply With Quote
Old 01-23-2003, 06:54 PM   #13
CosmoTheCat
Member#: 3409
98 My FMIC
I'd like the problem fixed.
I think I may have stretched a wire for the front O2.
Didn't see it when I went to drop my exhaust down. Oops.
Old 01-25-2003, 12:44 AM   #14
pdximpreza
Member#: 17606
2002 Impreza 2.5RS
The problem is, is when you open up the exhaust the output voltage of your O2 sensors drop. I believe we get a 420 right, cat inefficiency code? Meaning probably the difference between the 1st O2 and the 2nd O2 voltage is too seperate. You could just grab a DMM, and measure the voltage. Then do it on a car that gets the CEL. The just put a potentiometer tapped to the signal line to the CPU and to power. adjust the pot to bump the voltage up if needed. If it has to go down, run the potentiometer to ground.
Just to add; this is just a suggestion, it may or may not fix your problem. Splicing of wires is required, I take no fault for you dickin up your car.
P.S. when I get back home from my business trip, and I have the cobb full exhaust to put on. If I get a CEL, I will try what I wrote above =)
pdximpreza is offline   Reply With Quote
Old 01-25-2003, 12:53 AM   #15
pdximpreza
Member#: 17606
2002 Impreza 2.5RS
Could be a noisy signal too. If someone could take a trace of this signal on a good car vs a bad car that would be sweet. Most people dont have trace saving O'scopes though. They expensive.
Does the uppipe need to be replaced with borla header 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-14-2004 12:00 AM
Dealers and the ecu recall roninscar Warranty Issues & SOA Problems 3 07-02-2002 11:44 AM
Question for those have Borla Headers and the Subaru front skid plate V6 Normally Aspirated Powertrain 2 04-14-2002 11:59 PM
A question for anyone with borla headers? Pete Holt Normally Aspirated Powertrain 10 03-06-2001 05:53 PM
ATTN: Anyone with Borla Headers and CE light!!! m750 Normally Aspirated Powertrain 2 02-16-2001 12:20 AM
