Old 12-10-2012, 12:46 PM   #1
ScoobyDrift
Member#: 315446
2004 Impreza 2.5L
Default Intake Manifold
Advice: Can a WRX 2.0 Intake Manifold fix on a 2.5 SOHC without any mods done ?
ScoobyDrift is offline   Reply With Quote
Old 12-10-2012, 08:27 PM   #2
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Probably not, and why would you want to?
Counterfit is online now   Reply With Quote
Old 12-11-2012, 09:16 AM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
It will fit on an 04 such as your profile indicates. It will not offer any improvement over what you have, and will actually HURT performance unless you gut the TGV's.
There are better choices.
Jay
Old 12-11-2012, 10:35 AM   #4
ScoobyDrift
Member#: 315446
2004 Impreza 2.5L
Thanks Storm what options do u suggest?
Old 12-11-2012, 01:33 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
05+ SOHC EJ25 manifold. Best manifold Subaru makes by far. It will require some work to make the drive by cable throttle body work, but it is well worth the effort.
Jay
Old 12-12-2012, 02:31 PM   #6
ScoobyDrift
Member#: 315446
2004 Impreza 2.5L
Thanks bro.
Old 12-12-2012, 10:21 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
No problem. It has tested to flow just under the Cosworth manifold, which many consider to be the ultimate manifold for a Subaru motor. I changed from a '00 EJ25 manifold to an '06 EJ25 manifold and picked up 32hp (on a heavily modified NA motor).
Jay
Old 12-13-2012, 09:24 AM   #8
ScoobyDrift
Member#: 315446
2004 Impreza 2.5L
Nice, what kind of Mods do you have
Old 12-13-2012, 10:14 AM   #9
Storm
Member#: 5218
96L Most Over-
Developed Beater
12:1 compression pistons, 100mm bore, port/polished heads with Delta 3000 grind cams, EJ257 crank/rods/oil pump, 9.5 lb flywheel, WRX injectors, 70mm ford throttlebody, Techworks longtube header and standalone engine management.
Jay
Old 12-17-2012, 07:52 AM   #10
ScoobyDrift
Member#: 315446
2004 Impreza 2.5L
I got the EMS, TWE Stage II Cams 12lb Flywheel and Borla Headers, will work on the Pistons, Crank/rods and other stuff.
Thanks
Old 12-17-2012, 08:51 AM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
Sell the Borla's and put something useful under there...... I haven't tried the Moore Performance header yet, but I hope to very soon. The design looks solid. The Borla is just a noise maker (beautiful blatty boxer rumble that it is) and they crack if you look at them wrong.....
Jay
Old 12-17-2012, 10:40 AM   #12
KSTech
Member#: 143570
Jay
This is good advice, as that is a well-designed manifold.
The WRX manifold has a plenum that is way too small, and even with ported TGV's I would think performance would suffer. That manifold was designed with TMIC mainly in mind.
KSTech is offline   Reply With Quote
