Old 01-24-2013, 04:00 PM   #51
EM101
Member#: 324428
2013 Impreza
Marine Blue Pearl
Originally Posted by tsigeoff View Post
I just got new wheels from tirerack with new tpms installed for my 12 wrx. I just went to my local Monroe brakes and they did it for free. Took about 5 mins to get the codes into their handheld machine then programmed into the ecu. Easy as pie
It's not the '12 that has the issues, its the '13 model Impreza. Every tire place other than the dealer can read the sensors but can't write them to the car.
EM101 is offline   Reply With Quote
Old 01-24-2013, 04:31 PM   #52
tsigeoff
Member#: 314721
2012 WRX Limited
whoops sorry!
tsigeoff is offline   Reply With Quote
Old 01-26-2013, 04:51 PM   #53
Mgeorge8
Member#: 342878
Originally Posted by Mgeorge8 View Post
I got winter tires put on with tpms and tirerack said they MUST be programmed by dealer. I learned this the hard way by spending a few hours at STS while they tried to figure it out. The Subaru dealer wants $50 to program all four tires.
Had this done today at the dealership. Cost:$47 Paid: $0 . Thanks to Subaru Dollars from Mastercard.
Mgeorge8 is offline   Reply With Quote
Old 02-13-2013, 06:43 PM   #54
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
good deal tsigeof.
i just got the ATEQ-Quickset set up today with my snows / steelies (winter). i have two options at this point because I had the Subaru dealer program my snows.
1. check with the tire places to activate my OEM wheels / summer tires once the light comes on in the spring...
2. get them from Subaru. you would think they would include those codes with your Invoice or Manual, kinda like the roadside assistance cards with the VIN.
the set up was pretty easy on Windows 7, 64 bit - just make sure you download the drivers from the website.
i'm NOT sure if this step is actually needed, but if you have a Cobb AP or Tune, you may want to uninstall it before you try to pull your existing codes from the ECU. i asked cobb right here on NASIOC about it and they suggested to do it. so i did.
1. uninstall Cobb AP.
2. pull codes using ATEQ Quickset
3. reinstall Cobb AP
4. connect ATEQ Quickset to your computer and save the codes into the software. PRINT the sheet. *highly suggested just incase you loose the data or the software for whatever reason.
done. i'm very excited i won't have to go back to the dealer or anywhere else for TPMS for as long as I own this car.
Also, it works with other cars and you can have up to 4 vehicles sensor info with one device... (print all codes).
hope this helps. it's well worth the $150 to me. no more hassle and no more stupid light.
PS: i set up my 2012 WRX as a 2011 Impreza. there aren't any options passed 2011 IIRC.
ChesterWRX is offline   Reply With Quote
Old 03-08-2013, 04:06 PM   #55
aeoporta
Member#: 334126
2013 5mt Sp Premium
Venetian Red & Dark Gray
Ateq tpm Quickset works with 2012 and 2013 subaru impreza 2.0i NA
I have aftermarket sensors in the wheels: TPMS: 315 MHz Tire Pressure Sensor
I was able to retrieve the sensor id for winter tires and then I entered in the summer wheel sensor ids and then updated the cars ecu.
I then retrieved from car's ecu to confirm that the new codes for the summer wheel were in the computer.
The total for the tpms sensors was 144, the tpm quickset was 150, Dealerships sometimes charge 100 or more to do the
switch over.
ATEQ QuickSet TPMS Reset Tool : Amazon.com : AutomotiveATEQ QuickSet TPMS Reset Tool : Amazon.com : Automotive
ateq quickeset version 3.02 Beta 8
Version 3.02 Beta8 - V
quickset firmware: QD1-45
Database version: 20130108
OS: windows 7 64bit
Installed the drivers first, then installed the ateq software.
After software install ran update with tpms device plugged in.
Updated database and device
Choose 2012 subaru impreza even if you have a 2013 as they are the same car
NOTE: WHEN ORDERING FROM TIRERACK HAVE THEM SEND YOU THE SENSOR IDS, YOU HAVE TO TELL THEM THIS WHEN YOU ORDER AND ALSO WHEN THEY CALL TO TELL YOU THAT YOU HAVE TO GO TO THE DEALERSHIP TO INITIALIZE THE NEW SENSORS.
FYI:TPMS provisions were updated end of 2011
http://www.dunntireblog.com/consumer...ct-tpms-ruling
http://tires.about.com/od/Tire_Safet...ng-Sensors.htm
http://www.tirereview.com/Article/95...tpms_regs.aspx
aeoporta is offline   Reply With Quote
Old 03-09-2013, 04:16 AM   #56
hi5.0
Member#: 340456
2013 Impreza
good info! should save some coin when changing wheel/tire combo.
hi5.0 is offline   Reply With Quote
Old 03-22-2013, 11:25 PM   #57
N.G.S.
Member#: 334310
2012 Mitsu Evo X
I might have a solution for the tpms issue. I am looking for someone in the NYC/ NNJ area to be a guinea pig. Here is a link to an Evo forum thread that explains it.
http://forums.evolutionm.net/evo-x-t...oven-work.html
N.G.S. is offline   Reply With Quote
Old 03-23-2013, 11:36 AM   #58
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
subscribing for future reference
flyboy1100 is online now   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 05:14 PM.
