Old 12-11-2012, 04:52 PM   #1
squarebush
Member#: 173656
Default how bad SHOULD my engine be running?
So I just finished a 2.5 Build to swap into my WRX. I'm running it like a hybrid, as in, all WRX sensors, wiring, and ECU) she starts and runs BUT does NOT like running in closed loop. She runs fine on the throttle, but dips hard or even dies when I let off the throttle causing it to switch back to closed loop running. I have changed EVERYTHING abount this engine so I believe it to just be a problem of having the different MAF housing, but it seems to be reacting a lot like a vacuum leak, but it held 20PSI fine when I did a boost leak test. I also noticed that there seems to be quite a bit of air flow through the PCV valve.
Currently tuned for:
stage 2 wrx
TGV deletes
custom FMIC
SPT intake
Current engine:
2.5 block with 8.9:1 weisco pistons 100mm
lightened and balanced rotating assembly
255 heads, deleted avcs, +1mm valves, wrx cams
megan UEL header
custom 3" maf housing (stock that has been taken out of the air box, and significantly bored.)
TD04 19T IWG (for beak in miles, my HTA68 is out for a re-build)
820cc injectors topfeed
2.5i manifold customized to work with DBC throttle body
VTA (temporarily) BOV
catless
amy input on mechanical vs. Tune culprit would be appreciated.
squarebush is offline   Reply With Quote
Old 12-11-2012, 05:11 PM   #2
04ScoobyWtf
Member#: 287974
What mods did you put on when you put it back together? That aren't tuned for
04ScoobyWtf is offline   Reply With Quote
Old 12-11-2012, 05:16 PM   #3
squarebush
Member#: 173656
everything.... literately.
Old 12-11-2012, 05:18 PM   #4
ToneWrx02
Member#: 239095
2002 Wrx
so ur not tuned for the new parts. ..
ToneWrx02 is offline   Reply With Quote
Old 12-11-2012, 05:24 PM   #5
squarebush
Member#: 173656
no, I need to get it to run long enough to get it to my tuner. I assumed apparently wrongly that the old tune would run it "enough" that I could drive the 30 mins to my tuner (kinetic motorsports) I emailed my tuner and asked if he could email me a base map(my friend has a tactrix), but I'm still not sure if there is something mechanically wrong.
Old 12-11-2012, 05:31 PM   #6
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
Are you throwing any check engine codes?
02rex62 is offline   Reply With Quote
Old 12-11-2012, 06:19 PM   #7
squarebush
Member#: 173656
Only one i know of is Evap i haven't plumber in the soenoid yet, i will check again after dinner.
Old 12-11-2012, 06:21 PM   #8
02rex62
Member#: 215004
02 Rex
So you changed your injectors without changing your tune?
Old 12-11-2012, 06:24 PM   #9
squarebush
Member#: 173656
P0102, maf signal low input. Works with my maf housing theory. So basically i thing i just really need my maf scalled
Old 12-11-2012, 06:27 PM   #10
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Dude. Don't run your car. Your MAF is all messed up and your injectors need to be tuned for too. Those two things alone are enough to **** up your car, especially with a freshly built engine. You're lucky if you haven't ruined it already. Forget the fact that you're using a tune for a 2.0 for a 2.5 and an aftermarket turbo.
drewvdw is offline   Reply With Quote
Old 12-11-2012, 06:28 PM   #11
squarebush
Member#: 173656
Yes, I'm trying to get it stable enough to drive to the tuners. It's a completely new engine and i know it needs tuned, my problem is getting it there safely. I'm also not sure if my problem is entirely tune related. That's my main question, what should it run like with a way wrong tune?
Old 12-11-2012, 06:29 PM   #12
02rex62
Member#: 215004
02 Rex
Are you sure your maf is plugged in? Even with the maf not scaled right I'm pretty sure it shouldn't be throwing that code!
Old 12-11-2012, 06:29 PM   #13
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
It shouldn't be run at all without a tune. Flatbed or trailer it to your tuner.
Old 12-11-2012, 06:32 PM   #14
squarebush
Member#: 173656
Is the problem entirely tune? That's what i am asking.
It needs to run to be tuned, I'm working on getting a base map, but that would be a lot easier if i could .get the car to the tuners
Old 12-11-2012, 06:33 PM   #15
squarebush
Member#: 173656
I may have unplugged it with the key on while i was troubleshooting, i don't think it will come back if i delete it.
Old 12-11-2012, 06:36 PM   #16
02rex62
Member#: 215004
02 Rex
^Def a good option!
Old 12-11-2012, 06:55 PM   #17
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You changed the MAF housing size and the injectors. Tell your tuner your mods, he should be able to make you a map before tuning. And tow it to the shop and have deep pockets.
FuJi K is offline   Reply With Quote
Old 12-11-2012, 07:27 PM   #18
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
The tuner can't even make him a real safe limp map because he went and did a custom intake. What he needs to do is stop trying to run it to see if it's okay to run and bring it to the tuner. The tuner will be able to put a relatively safe tune in to get it running based on mods other than the intake, then he'll work everything else out.
OP, do yourself a favor and quit running the car before you need to build another engine. No, you don't have to run it in order to get a safe tune to start with. A good tuner will know what he has to do to start and run it safely at idle. Then and ONLY then will you be able to figure out if everything is done right.
Old 12-12-2012, 09:36 AM   #19
tja1618
Member#: 181995
2003 WRX
Because of things like this I'm leaning toward paying my tuner to come to my garage for my initial startup. Either that or towing it to the shop. You might as well pay someone with experience to help break in your new investment.
tja1618 is offline   Reply With Quote
Old 12-12-2012, 12:18 PM   #20
squarebush
Member#: 173656
I want to make sure eveyone who has been reading this knows I am NOT driving the car, I have run it for a few short runs to check for leaks ect. and am not ready to bring it to the tuner, I was hopping to drive it there, but it looks like I will be renting a trailer... except all the money I have at the moment is already destined for my tuner...
Old 12-12-2012, 03:39 PM   #21
thebeephaha
Member#: 248063
2003 Forester 2.5XTi
Supercharged in Gold
Doesn't matter if you aren't driving it or not, running it idle on a crap tune can still hurt the engine. Save up more cash, trailer and tune.
thebeephaha is offline   Reply With Quote
Old 12-12-2012, 03:57 PM   #22
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
1. Find buddy with trailer.
2. Get case of beer.
3. Ride with buddy to tuner.
4. Meet back to buddy's place.
5. ???
6. Profit.
Alternately, if you can't complete step 1, ask a buddy to see if they know someone with a trailer.
Old 12-12-2012, 04:29 PM   #23
squarebush
Member#: 173656
I've been calling all my friends trying to find a friend with a friend with a trailer, and nothing... All the shops I have out in use flatbed trucks for their transporting needs. I know my father has a semi-local friend with a trailer, but I'm not sure if I can get a hold of him, (A have a slot at the tuners for tomorrow morning. My tuner, who is VERY reputable, seems to think he can email me a base map so the car can make the 20 mi drive, but I'd still rather a trailer.
Old 12-12-2012, 04:49 PM   #24
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Who is your tuner?
Old 12-12-2012, 05:32 PM   #25
squarebush
Member#: 173656
