Old 12-11-2012, 10:07 PM   #1
Bugeye2.5
Member#: 295270
2002 Impreza OBS
Midnight Black Pearl
Default WRX rear diff question
I am bored of having open rear diff, so I am looking at upgrading to a WRX rear diff. I was wondering if anybody has done this and if there is anything else I need to swap over also or am I okay with only swapping the diff?
Bugeye2.5 is offline   Reply With Quote
Old 12-11-2012, 10:54 PM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
check the transmission/driveline forum. I think you have to swap the ring/pinion gears so the diff will bolt up and you will want one that matches your transmission ratio so you don't cook your center diff. Something about what years you can use,etc
Old 12-12-2012, 10:39 AM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
It's a simple swap. Put both diffs next to each other, open and remove both center sections, pull both ring gears, put your original ring onto WRX center section, put your new LSD into your original housing and check the gear mesh pattern via the factory service manual. Adjust if necessary or install back into the car. Same axles can be used.
Jay
