Old 11-27-2009, 11:01 PM   #1
J_Bird
Member#: 230111
Thumbs up 2008 Subaru Impreza Hatch Front/Rear Door Panel Removal
I just found a PDF file that shows how to do this with great detail. The only thing is I'm not sure of the best way to share it.
***EDIT***..... I found one option for the PDF file.
Here is a link for the file.
2008 Subaru Impreza Door Removal
J_Bird is offline   Reply With Quote
Old 11-28-2009, 11:05 PM   #2
J_Bird
Member#: 230111
Step 1: Open small cover & remove screw.
Step 2: Open small cover and remove screw.
Step 3: Use a screw driver with a wide edge (keeping it horizontal) in this slot to pry up and start to release the clips. Once started finish removing by hand.
Step 4: Then remove these two screws, and disconnect the power windows/locks harness(s)
Step 5: Then carefully pull out & back toward the window to release the tweeter near the mirror.
(This is where the clip is that you are removing)
Step 6:Now just pull the door panel firm but gently up and you should see this.
(I was surprised at what I found when I got the door panel off. I was suspecting that I would find a paper plate and a rubber band. But, instead I found a 2-way!)
Step 8: There are three screws holding the speaker in the door, remove these.
Step 8: If you are going to be changing your speakers and purchased new models that can use the factory mounting plate, then you will need the remove the six screws that are holding the original speaker
Once you've done one door the rest should be simple. The rear doors are very similar to the front doors. The only difference is that before you pull the door panel up and off you will need to carefully remove the triangular piece of plastic from the area rite above the door panel towards the back of the car. It is held on by one clip as well.
I found that you need to be a little bit more careful on these than anything else.
Old 12-04-2009, 05:11 PM   #3
DaveC113
Member#: 126901
2010 WRX 5 Door
The link doesn't work and all the pics are red "x"s.
DaveC113 is offline   Reply With Quote
Old 12-04-2009, 05:50 PM   #4
subyski
Member#: 202642
08 Impreza,80Vette
68 Impala, 15 SantaFe
Great info. Thanks for posting.
subyski is offline   Reply With Quote
Old 12-04-2009, 06:17 PM   #5
ezod52
Member#: 171980
2009 WRX 5Dr
nice. i haven't taken my door panels off yet and i was wondering how hard it was. great to see a walkthrough. thanks.
ezod52 is offline   Reply With Quote
Old 12-23-2009, 10:08 AM   #6
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Looks good, just in time for me to install the speakers I got from Amazon yesterday.
JourdanWithaU is online now   Reply With Quote
Old 12-24-2009, 11:59 AM   #7
DaveC113
Member#: 126901
2010 WRX 5 Door
works now, thanks for posting
Old 07-25-2010, 09:09 PM   #8
Gdave89
Member#: 247520
2008 Impreza 2.5i
Thanks for the post just got brand new Polk audio
Gdave89 is offline   Reply With Quote
Old 07-26-2010, 02:07 PM   #9
hjmik
Member#: 222835
2007 Forester
Good info thank you!
hjmik is offline   Reply With Quote
Old 09-01-2010, 10:50 PM   #10
Thesystem3
Member#: 233014
2008 Impreza Hatch
thanks man, this helped alot! just replaced my stock speakers with well, worse ones, they are going back tommorow.
Thesystem3 is offline   Reply With Quote
Old 09-14-2010, 11:02 AM   #11
Subirex09
Member#: 207880
2013 STi
Awesome SWP
Awesome post, I held off on upgrading my speakers this past weekend because I was dreading what would be required...but this tells me it's not so bad after all.
Subirex09 is online now   Reply With Quote
Old 09-14-2010, 11:22 AM   #12
parabellum9x19
Member#: 255720
2008 Impreza WRX
Good lord door panel removal is so easy on pretty much all modern cars.
The steps for ALL cars are basically the same:
Locate and remove all screws in the door.
Remove any parts of the door that were held on by those screws.
Look again for new screws revealed by the last step, remove them.
Pop off the door panel starting at the bottom.
Lift the door panel off the top lip once all the plastic clips have been popped out.
If you need access to the window regulator, carefully remove the vapor barrier and any crash foam in the door.
Reverse to install.
parabellum9x19 is offline   Reply With Quote
Old 12-30-2010, 11:24 AM   #13
ejhayes76
Member#: 267923
2011 Impreza 2.5i
I will echo about being careful with the rear triangle sail panels. You have to pull them straight out, or the clip will break. I broke the first one I removed and had to order a replacement panel @ $7 from subaruonlineparts.
The other issue I had was removing the screw cover in the armrests. I found an eyeglass screwdriver was able to pry the cover up from the front cover of the cover.
ejhayes76 is offline   Reply With Quote
Old 12-30-2010, 04:05 PM   #14
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
This procedure is missing just one detail, unhooking the lock and handle cables, you can't take the interior panel off and set it aside without it.
It is similar to other cars if you have done it before. When you pull the trim panel away from the door, the cables will be accessible from the back.
Right up close to the lock switch and handle backside, there is a little plastic clip that you can snap away, I think they are green or yellow, you can see they are holding the cable end down. Once you snap the clip off the cable and pivot it out of the way, you can pull the cable up and out of its seat, disconnecting it from the door trim.
Power6 is offline   Reply With Quote
Old 12-30-2010, 04:57 PM   #15
STi__G
Member#: 206414
2009 STI
Thanks for the info!
STi__G is offline   Reply With Quote
Old 01-01-2011, 07:35 AM   #16
RallyBlueBill
Member#: 267118
2011 WRX 4 door
World Rally Blue
Just the guidance I need to fix the famous 2011 door panel rattles!
Fantastic thread!
Thanks!
RallyBlueBill is offline   Reply With Quote
Old 01-01-2011, 12:00 PM   #17
Drew12
Member#: 218453
2009 WRX
Dark Grey Metalic
Fantastic thread!
Thanks!
Save yourself the trouble and take it to the dealer for warranty repair.
I went in for oil change, mentioned the rattle in the right door, and it came back nice and quiet.
One reason for a new car is the new car warranty, use it.
Drew12 is offline   Reply With Quote
Old 01-01-2011, 03:15 PM   #18
Dabrador
Member#: 267790
2011 Outback Sport
Originally Posted by Drew12 View Post
Save yourself the trouble and take it to the dealer for warranty repair. One reason for a new car is the new car warranty, use it.
Exactly. I too had a rattle in the front passenger door. As easy as it is for a non-tech to remove the panel, the guys in the service department at the dealership can do it even faster.
You paid for the new car warranty, why not use it.
Dabrador is offline   Reply With Quote
Old 01-02-2011, 09:34 AM   #19
hotrodmike
Member#: 242429
2010 STI
Dark grey
Thanks this helped a lot.
hotrodmike is offline   Reply With Quote
Old 01-13-2011, 08:55 PM   #20
David920
Member#: 168092
2011 WRX 5-Door Prm
Obsidian Black
K, I'm an idiot and took off the wrong clip. A spring popped out and have no idea how it goes back together. Anybody know where I can get a replacement part?
David920 is offline   Reply With Quote
Old 01-14-2011, 01:46 AM   #21
MarcoPolo360
Member#: 265006
2011 2.5i 5MT
World Rally Blue
try https://www.subarugenuineparts.com/oe_parts_cat.html
MarcoPolo360 is offline   Reply With Quote
Old 01-14-2011, 03:01 PM   #22
David920
Member#: 168092
2011 WRX 5-Door Prm
Obsidian Black
Originally Posted by MarcoPolo360 View Post
I would, but I don't know what the part is called. I'm just going to head down to their dealership today since its only 5-10mins away from my work. Its either they can help me, or I may have to order it from them (for some reason pick-ups arent allowed if I order from that site :/).
Old 02-04-2011, 11:05 AM   #23
David920
Member#: 168092
2011 WRX 5-Door Prm
Obsidian Black
I found the part through a the Subaru eStore (basically local dealer that has an eStore through Subaru). Pretty easy to navigate. Though its for 08-10' its prb the right part. I'll just wait for confirmation tho.
http://parts.subaru.com/replacement/...layCatalogid=0
Old 02-26-2011, 09:21 PM   #24
cbigbie191
Member#: 275192
Thanks for the info. but where in the door panel are the rattles coming from on the 2011 Impreza?
cbigbie191 is offline   Reply With Quote
Old 02-28-2011, 06:57 AM   #25
MarcoPolo360
Member#: 265006
2011 2.5i 5MT
World Rally Blue
Problem: Annoying rattle
Cause: Two white plastic "boxes" inside the bottom portion of both door panels.
Solution: Remove them.
Result:
WRX rear door panel removal WRXBjlevy Car Audio, Video & Security 11 01-03-2014 01:28 PM
JDM Subaru Impreza GC8 STI Interior Door Panels cash-manny-money SCIC Private Classifieds 8 07-03-2009 05:13 PM
Rear door panel remove WRX_06 Newbies & FAQs 3 09-13-2006 03:01 PM
WTB: 2000-01 Impreza RS SEDAN rear door panels Texas25RS Private 'Wanted' Classifieds 1 11-08-2005 03:01 PM
STi rear door panel removal - window switch trim? das Car Audio, Video & Security 1 08-18-2003 02:02 PM
