Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 12-12-2012, 06:19 PM   #1
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
Default Anyone running remote auto start on a manual?
Anybody running an auto start from a remote on their cars thats a manual? im interested in one and wondering if anyone using one would give some insit on what a good one would be.
dumpstercrusher is offline   Reply With Quote
Old 12-12-2012, 07:53 PM   #2
JDMSTA
Member#: 310615
1213 12'Sport+13'STi
Satin White Pearl
I'm currently using this system on my car and I love it even though its just a base model one. http://www.adventproducts.com/remote.../?sku=PRO9051N
JDMSTA is offline   Reply With Quote
Old 12-13-2012, 09:56 AM   #3
luan87us
Member#: 335013
2013 Premium WRX 5dr
Wouldn't it be annoying if you forgot to take your car out of gear when you park? lol I know a lot of people park in 1st gear.
luan87us is offline   Reply With Quote
Old 12-13-2012, 10:00 AM   #4
yanksball14
Member#: 335344
2013 WRX Sedan
You would have to be very conscious of this^
yanksball14 is online now   Reply With Quote
Old 12-13-2012, 10:33 AM   #5
blessthekellen
Member#: 273859
MY98
WRX
On new remote start systems you must go through a setup process to ensure the vehicle is in neutral. Otherwise the vehicle will not attempt to start.
Dei products are:
Foot on brake.
Ebrake up.
Foot off break.
Press unlock on remote.
Vehicle keeps running when key is removed.
Get out, close door.
Press lock.
Doors lock, and vehicle turns off.
If a door is opened up after the setup is finished to say grab something from inside the vehicle, the setup cancels and you have to do the process all over again.
Compustar product is:
Foot on brake. Ebrake up.
Wait for click. Remove key.
Vehicle stays running. Get out. Close door.
Vehicle locks itself and turns off.
Same deal with reopening a door however.
So no. Putting remote start in a manual transmission in a reputable shop is not a big deal anymore.
blessthekellen is offline   Reply With Quote
Old 12-13-2012, 10:37 AM   #6
Tricky [RCAF]
Member#: 50183
1999 06 WRX, 99 Swap
CGM & BDP (Matte white)
The system has a safeguard for that. When I park it has to be in neutral with the park brake set, my feet have to be off the pedals and then I can remove the key and have the car continue to run, once I close the driver door the alarm is armed, the engine turns off and it is in remote starter mode.
Tricky [RCAF] is offline   Reply With Quote
Old 12-13-2012, 04:14 PM   #7
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
Dei products are:
Foot on brake.
Ebrake up.
Foot off break.
Press lock.
this sucks because i have those times i have to run out to the car. i rather have a system where it acknowledges the e brake pulled up and car in nuetral
Old 12-13-2012, 05:29 PM   #8
JDMSTA
Member#: 310615
Satin White Pearl
Mine was just plain and simple. just don't park it in gear and I'm all set. When in gear, the car won't start at all with the remote.
Old 12-13-2012, 05:30 PM   #9
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
how much was yours? i didnt see a price on the website you gave me
Old 12-13-2012, 05:37 PM   #10
JDMSTA
Member#: 310615
Satin White Pearl
I paid $150 which include installation.
Old 12-13-2012, 08:08 PM   #11
blessthekellen
Member#: 273859
MY98
WRX
This has to do with the install. The installer probably hooked the hood pin input to your neutral safety wire on your ecu. Subarus actually have a wire that throw a ground pulse when put in gear. If you hook the hoodpin input wire to this, this will cease the car from starting.
Old 12-13-2012, 10:06 PM   #12
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
i love that number as opposed to $500+
Old 12-14-2012, 02:16 PM   #13
JDMSTA
Member#: 310615
Satin White Pearl
Maybe, but looking at the manual. http://voxxintlcorp.com/docs/common/...RO9051N_OM.pdf That's how the system works so I really don't know if there's any other way to hook the system up.
Old 12-15-2012, 09:23 AM   #14
morse9443
Member#: 325412
2012 WRX
OBP Stg 2
No way. Alarm and install are worth a couple hundred each.
morse9443 is offline   Reply With Quote
Old 12-15-2012, 11:55 AM   #15
Erittz
Member#: 282506
2011 WRX
http://www.sonicelectronix.com/item_...FYxaMgodB0UABA
couple hundred? I'm sure they can get that much but dont have to be right? I'm completely uneducated with remote starts though
Erittz is offline   Reply With Quote
Old 12-15-2012, 12:24 PM   #16
Xaved
Member#: 337434
2013 WRX STI
Plasma Blue Pearl
I'm running a compustar on mine. Foot off the brake, e-brake up, shifter in neutral and turn off the key. The engine stays running and you get out. When you close the door the car automatically locks and shuts itself off. It won't remote start unless you follow this process. Essentially if your car is safe to run without you being in the seat it is safe to remote start.
I had them install one of these addons for the alarm on my windshield in case I ever lock myself out too:
What I thought was really cool was that when they installed it, they piggybacked it off of the OEM keyless system so if I mute the aftermarket siren beep alerts the car uses the OEM chirp sounds.
Xaved is offline   Reply With Quote
Old 12-16-2012, 02:45 PM   #17
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
My 2008 Forester XT 5MT came with an aftermarket remote start which had the e-Brake safety wired in, but unfortunately not a neutral safety interrupter. I ended up wiring into the factory neutral safety switch (directly from the transmission harness).. When it is in gear the ground is incomplete and it will not start, when in neutral it will start. I'm not certain which brand remote start it is, but it activates when I hit Lock twice.
Stephen@iaperformance.com
IA Performance is offline   Reply With Quote
Old 12-17-2012, 12:27 AM   #18
jegomes
Member#: 303039
2006 WRX
That's just the basic hardware.. your gonna need extras for that to work in just about any car.. plus that does not include install which should be 180 to 210.. or abouts, and if you want a warranty it needs to be installed by a compustar authorized shop
jegomes is offline   Reply With Quote
Old 12-17-2012, 10:43 AM   #19
simauy
Member#: 340860
Great thanks
simauy is offline   Reply With Quote
Old 12-17-2012, 06:09 PM   #20
JDMSTA
Member#: 310615
Satin White Pearl
Sorry, actually I paid $250 for it. I had a friend of a friend that works at a car audio store hook me up by me going after hours to install.
